afr or prc heads ?????
The economics of situation will dictate your budget and a decent low $ head is better than stock. Just be honest about how far you want to take the car and how much you race. The more you race, the unhappier you will be if compromise on your heads.
just some FYI there's a 383 with mild cam, bolt ons and out the box 225's that should best your numbers by 30-35rwhp. should be posted shortly.
Ragtop hit the nail on the head in this thread
52172 - AFR isnt running into any trouble, they've already proven themselves in the market. Time will tell how the other aftermarket heads play out in the real world. and talk to Pat (Pdd) and 2c5's and see what kind of "magic" TEA is working on those AFR castings. stop spreading rhetoric on which you know nothing about.
like i said, time will tell how things pan out in the real world and what kind of combo's people are putting together. also am curious to see what type of intakes these large flowing heads are going to see. also, keep in mind numbers on a bench or theorized dont always translate into the desired e.t or dyno numbers.
When can I send you one of our heads to flow test, since you have never had the oportunity to do so. Please don't forget, TEA is under new ownership and our quality and performance have never been better.
Its all good.
like i told brent a some weeks back, steve is busy getting the new 4.200 sleeve's ready and i'd contact him (brent) when steve had some free time. but seeing as how brent has moved on i'll pm you when the time comes.
AFR 225 should get the job done. The hell with 205s now
