The wheels are in motion and the new bullet is on the way...
Shortblock:
LS6 Block Bored 3.905
Line Honed
ARP studs top, bottom, and rods
Katech Main caps
Clevite moly coated rod and main bearings
Scat 6.125" H Beam rods
Lightened LS1 Crank
Diamond custom one off pistons Coated skirts and domes
Lunati Solid Lifters
Top end:
ET Performance 225cc heads brand new castings
- Thermal Coated Exhaust valves and Moly coated springs
Comp 999 Springs
25x-26x custom solid roller .650-.700 lift
Jesel J2k Rockers
Comp Cams Pushrods
Cometic .045 3.910 gaskets
42# injectors
Fast 90mm Intake ported
NW 90mm TB
Power Adder:
Nitrous Express/ECS custom one off direct port 300 - 400 shot
ECS Standalone fuel system
Tuning:
Our custom SD tune
I am building 2 of these motors, one for my 6 speed and another for an automatic and we're hoping this will show the potiential of a nice street motor.
Phil
Phil
That sounds like the potential for some very nice times. What are your goals for this setup?Nate
2)How much NOS are you going to be hitting it with, and are you going to go progressive, or all-at-once?
3)What kinda ETs and MPH are you looking for in your (M6) car?
Sounds like a stout setup, Shawn
I think you could see the power your looking for
We're about the same except we're running a Hyd. Roller with a just bit less duration and a non-lightened stock crank. We're hoping to get a set of 225 AFRs to see what they can do.
cant wait for the results
