ATI Damper - Belt Jumping
When using the ATI Damper, resonance around 4,000 RPM may cause the belt to jump off the stock tensioner. The solution to this is a solid, adjustable tensioner that directly replaces the stock spring tensioner. This is a race only item.
Has anyone had a problem with the ATI damper and belts jumping off?
