6.0L Rotating assm.
there is a flow chart for LS1, LS6, 5.3 and 6.0 heads floating around here somewhere
second the "truck" crank is different in that has a wider seal pad (next to the flywheel), although are some exeptions in modern light duty trucks where there are narrow "car" seals.
of course the pistons are heavier (bigger size) but even the 350 lq4,etc have heavier pistons.
the rods are differnt too, the big end in truck rods have thicker walls, and the shape is different
with a 6L engine I would bolt a LQ4 heads, (simmilar in size and shape to the LS6-ZO6) but with lower compression and a HELLUVA CHARGER...... ;-)
