Will I have clearance issues with the following??
Old Sep 21, 2005 | 07:01 AM
Tommy Tucker's Avatar
Default Will I have clearance issues with the following??
I am putting the following on soon and am wondering if anyone has done the same or has experience to advise.
New PP 5.3 heads (2.02"/1.57")
GM Hotcam (already have it)
Crane 1.8 RR's (already have them)
Standard GM gasket.
Stock short block.
Thanks,
Tom.
Old Sep 21, 2005 | 07:06 AM
Billiumss's Avatar
You will be fine, that cam is not that big...
If you can, use the MLS GM head gaskets.
I'm going to guess with a good tune, you'll make 390-410 RWHP
Bill
Old Sep 21, 2005 | 07:23 AM
PREDATOR-Z's Avatar
218/228 525/525 112
Are your heads milled?/
If not then don't even worry, you'l have enough clearance to run a bus through there.
I would run Cometic .045 to better your quench and reducing detonation (+ a couple more HPs)
Old Sep 26, 2005 | 07:30 AM
Thanks guys for the help.
