ARP Balancer Bolt Removal
Old Sep 22, 2005 | 06:00 AM
vettenuts's Avatar
Default ARP Balancer Bolt Removal
Just getting ready to install the ARP balancer bolt. It calls for "RED" Loctite for installation. How do you remove this sucker later, has anyone done this and if so did you have to use heat?
Old Sep 22, 2005 | 07:39 AM
SideStep's Avatar
I have not installed one, BUT I have had to uninstall one that had tons of red loctite on it. Had to put the torch on it to get it out...
Good Luck,
Old Sep 22, 2005 | 08:13 AM
PREDATOR-Z's Avatar
Impact wrench when motor warm
Old Sep 22, 2005 | 08:17 AM
vettenuts's Avatar
I was hoping no heat would be required, but at least with an ATI damper you can remove the soft part of the damper to apply heat.
Old Sep 22, 2005 | 09:32 AM
vettenuts's Avatar
Lesson learned:
I just spoke with Permatex Tech Support. Heat is definitely required. I was told that unless there are corrosion issues, there is no need to coat the entire threaded length and that the last 1/4" of engagement (nearest 1/4" to the end of the threads in the crankshaft) is all that is required. This will aid later disassembly.
Good to know.
Old Sep 22, 2005 | 10:18 AM
PREDATOR-Z's Avatar
Lesson learned:
Good to know.
you can deduct that from looking at the GM bolt or any GM head bolts.
Old Sep 22, 2005 | 10:20 AM
vettenuts's Avatar
Lesson #2:
Just spoke to ARP Tech Support, they told me DON'T USE RED LOCTITE.
190 lb-ft of torque with their moly lube is the way it was designed. Since I pinned the crank anyhow, that is how I plan to assemble the unit.
Old Sep 22, 2005 | 11:31 AM
777's Avatar
777
Hmmm, All I did was tighten the bolt down as tight as I could get it with a 2" breaker bar. Have had no problems since. Even checked it a couple time and it didn't budge.
Old Sep 22, 2005 | 11:40 AM
vettenuts's Avatar
I think it is a combination of two things. I have the ATI damper that I am installing. It is very precise on the required interference fit, 0.0007-0.0009 inches of interference. It is the interference fit that should keep the hub from rotating on the crankshaft. (I have also pinned the crank.) I think with the correct interference fit, the damper should not spin (pinned or not) and there is no need for Loctite on the bolt as the bolt should not be loaded in torsion.
Problem may be the stock unit, once removed, no longer has the correct interference and for that reason may not be re-useable (my logic anyhow). The stock unit also has an aluminum hub, whose heat expansion characteristics are different than the crank, which may also play into this.
Guess I want to put this out there for those guys who are using the Red Loctite, you may have a problem later with disassembly.
Old Sep 22, 2005 | 12:11 PM
bowtieman81's Avatar
OK, I used a regular GM bolt on mine with the little bit of factory applied loctite. What I did was crank that sucker to about 110-115 degrees (spec is 140), then took a paint pen and drew a line on the bolt head and onto the balancer so that I could glance at in once in a while to see if its loosening.
Now, for your bolt I would not use red loctite, just teh blue stuff.
Old Sep 22, 2005 | 06:10 PM
Grimes's Avatar
Don't worry about it - since you're already using the pin kit, just use a little bit of blue loctite on the end, and call it a day.
