LS2 blocks..
Old Sep 23, 2005 | 10:36 AM
Y2K SS's Avatar
Default LS2 blocks..
Where is the best and cheapest place to buy them???
Old Sep 23, 2005 | 12:40 PM
CAT3's Avatar
Restricted User
Have you tried Scoogin Dickey----> sponsor? Wayne, why do you want a LS2 Block anyway? As worried as you are about the little KR you had before, you'd flip not knowing if there was any KR on the LS2 swap. You need tires, 9" rear, and ***** to launch that POS at higher RPM.
Old Sep 23, 2005 | 12:59 PM
Y2K SS's Avatar
just curious foo, incase something happens to my motor I was just getting some ideas.
Old Sep 23, 2005 | 04:25 PM
KJ's Avatar
KJ
We have LS2 blocks at a very good price!! I have them in stock for $995.00 + a little freight to get it to you. Let me know if I can help!!
Just a quick note. You can use the knock sensors on the LS2 block. All you have to do is use LS1/LS6 sensors on each side of the block. In fact I have knock sensor & cam sensor harnesses being built for a plug & play set up on F body & C5 Corvette
Old Sep 24, 2005 | 01:29 AM
Y2K SS's Avatar
SAWEET.... I'll let you know when I decide. I kinda wanna see some results from others though first. Just checking all the options.
