stock pushrod length?????
Old Sep 24, 2005 | 09:05 PM
CoBIZZLE's Avatar
Default stock pushrod length?????
I got a 98 z-28 and bent half the pushrods on a missed shift. I have tried to order new ones twice and have been given the wrong length both times. I been told it is 7.4". Does anyone know???
Old Sep 24, 2005 | 09:18 PM
mrr23's Avatar
7.400 is correct.
Old Sep 24, 2005 | 10:27 PM
bigdsz's Avatar
Try 7.38". That's why you frequently have to buy aftermarket 7.40" when you install an after market cam, due to the smaller base circle.
Old Sep 24, 2005 | 11:00 PM
mrr23's Avatar
my mistake. they are 7.380.
Old Sep 25, 2005 | 07:30 AM
PREDATOR-Z's Avatar
7.40 will work on stock motors. Your preload will increase by .02 but that is still well within the acceptable range of the stock lifters.
Old Sep 25, 2005 | 08:08 AM
98A4LS1's Avatar
Seems like there was a thread about two months ago, stock PR's removed from 98 Z and were measured at 7.40.
Old Sep 25, 2005 | 10:46 AM
redtail2426's Avatar
the rumor of 7.38 is not correct i had a set micd by a machinist on 2 machines and they average 7.395.The longest was 7.398 and the shortest was 7.393.i dont know where this 7.38 came from but its not right
Old Sep 25, 2005 | 11:43 AM
PREDATOR-Z's Avatar
Wel as you said yourself, you had variations in 1 set.
I measured one from my 01 and it was 3.84
So we can conclude that they range from 3.8x> 3.9x (must depend on where they were made or since they are not hardened, that they stretch.)
Old Sep 25, 2005 | 01:48 PM
yeah they must have been made in a different plant or something.you can see the variations in the tips of the pushrods that makes one longer then the other.the hole n some of them is off center a little bit making it a hair longer.I bet when they are installed the height difference has much less variation.you will see what i am talking about if you really look close at the tips.
Old Sep 25, 2005 | 03:23 PM
davered00ss's Avatar
Moderator
Get a set of hardened 7.40's.
Old Sep 25, 2005 | 10:42 PM
Z06er's Avatar
Old Sep 27, 2005 | 04:51 PM
mrr23's Avatar
well then, i guess i'll retract this statement until further verify-able proof exists.
Old Sep 28, 2005 | 05:42 AM
camaroguy26's Avatar
you're best off getting a tool and measure the actual length you need, just rent one from autozone or something, you gotta tear the car apart anyways right? The stock pushrods are weak and were all machined to one size so they could have been shorter or longer than being perfect.
