Looking at 427 C5R
Old Sep 27, 2005 | 09:43 AM
JakeFusion's Avatar
Super Hulk Smash
Forget Ross or Diamond. Go with CP. CP makes their pistons specifically for boosted/nitrous applications. Order it with an inverted dome designed for nitrous and sleep well at night.
Old Sep 27, 2005 | 10:25 AM
PREDATOR-Z's Avatar
I will look into that.
Another Q:
Will the C5R block accept knock sensors? If so which kind?
And what about PCV setup? LS1 or LS6?
Old Sep 27, 2005 | 09:31 PM
JakeFusion's Avatar
Super Hulk Smash
I haven't heard about it not accepting the stock knock sensors, so I would assume it does. Go with the LS6 PCV, since it's supposedly better. Or, run your own catch can type of setup using the LS6 PCV.
Old Sep 27, 2005 | 09:45 PM
LASTLS1's Avatar
6 Second Club Moderator
In my old 427 I had a 244-250 and the idle was very tame! Too tame. But it made 520rwhp through a th350 , 12 bolt, steal drive shaft and slicks. It also was a pump gas motor. Call Speed Inc for the cam.
Old Sep 27, 2005 | 10:07 PM
RUTAN TA's Avatar
call Mike at Phillips racing engines and he can get you custom pistons @614-875-0040 tell him John told you to call
