Arp Molly-Lube
Originally Posted by ashade98
Who know's where to get it? I thought it came with the bolts
. Links???
Thanks
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Thanks
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Anyplace that sells the fasteners probably sells the lube. Mine came from Thunder as well. I thought the kits usually came with a small tube, but that seems to have gone away. A lot of folks have been reporting that their fasteners didn't have any.
you can order it from summit I got that and some of the teflon thread sealer and also the edelbrock gasgacinch stuff with all the crap to build the motor.
something else I don't know if it is true (gotta look into it) they say the molylube is slicker than oil and the tourque values need to be lower
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
ARP sets their torque values and conducts their in house testing for fastener pre-load based on their lube. Other lubes (such as oil) may result in the requirement that a new torque value be used to obtain the same fastener pre-load. It is the pre-load you are trying to achieve in a reliable manner, not a torque value.
