Quick - Name That Lifter
Old Oct 1, 2005 | 05:59 PM
TAQuickness's Avatar
Default Quick - Name That Lifter
Need some help identifying the make, model, and manufacturer of this lifter.
The only marking I can find on it is "1G5" or "1C5"
Also, would anyone be so kind as to post up photo's of a stock OEM lifter - thanks
Old Oct 2, 2005 | 01:01 AM
racecar's Avatar
Not a Comp R, not a Morel, I have had both of them and they don't look like that.
There is not much surface on that thing. I would be worried that would cause extreme wear on the aluminum block.
Old Oct 2, 2005 | 09:34 AM
ashade98's Avatar
Not a comp replacement either, I'm GUESSING stock????
Old Oct 2, 2005 | 09:43 AM
ashade98's Avatar
Check out this link, it's for ebay
http://cgi.ebay.com/NEW-GM-Corvette-...QQcmdZViewItem
Old Oct 2, 2005 | 09:50 AM
01TA's Avatar
Looks just like the stock ones out of my '01.
Old Oct 2, 2005 | 10:40 AM
PREDATOR-Z's Avatar
looks like stockers to me
Old Oct 2, 2005 | 10:48 AM
thanks guys
I'm still in the process of searching my next question - but in the mean time - how do I go about inspecting these to make sure they are good?
I was under the impression I should be able to sqeeze the plunger (for lack of better terms).
Old Oct 2, 2005 | 10:52 AM
PREDATOR-Z's Avatar
looking at the scuffs on the sides, I would inspect the lifter bores as well.
If they are over 50K miles then change them.
I recommend Comp 850-16 with cams less than .600 lifts and less or at ~ 230 durations.
Old Oct 2, 2005 | 10:55 AM
they will be replaced with a set of morels in the very near future. Just wanting to inspect for damage.
