Main Cap removal
Old Oct 4, 2005 | 04:19 PM
Phil99vette's Avatar
7 Second Club
Default Main Cap removal
Whats the best way to remove the main caps once you have removed the main studs and side bolts(crank in block)? Do they make a special tool to loosen them?
Phil
Old Oct 4, 2005 | 05:30 PM
72ChevelleConv.LS1's Avatar
use a rubber malett and tap them back and forth.
Old Oct 4, 2005 | 05:36 PM
ROCNDAV's Avatar
I used a big screw driver and rag to pray them back and forth.
Old Oct 4, 2005 | 05:49 PM
family sedan's Avatar
Rubber mallet all the way.
Old Oct 4, 2005 | 11:43 PM
7 Second Club
What about with the Katech Main caps where they are pinned to the block.
Phil
Old Oct 5, 2005 | 02:04 AM
strokedls1's Avatar
No clue about the katech ones, but I use a rubber mallet like the rest of these guys.
Old Oct 5, 2005 | 01:38 PM
bulletLS1's Avatar
pry with a flat screwdriver very VERY litle each side at a time take your time, dont use too much force, the force needed for a LITTLE wont mar the aluminum from the block
Old Oct 5, 2005 | 01:43 PM
2001 Pewter WS6's Avatar
Restricted User
Use a rubber mallet
