Does anyone make a graphite head
Old Oct 9, 2005 | 10:05 AM
Taspeed's Avatar
Default Does anyone make a graphite head
gasket for the 6.0 standard bore?
Old Oct 9, 2005 | 11:15 AM
PREDATOR-Z's Avatar
Not that I know of, MLS is where it is at from factory.
Old Oct 9, 2005 | 12:19 PM
Taspeed's Avatar
Hmmm...anyone know anything about the mls gaskets leaking with the 5.7 heads with notches in them? Not sure I should even bother putting them on. I have a set of 5.3's that I haven't finished the port work on, so these were going to be temporary. Guess they may be really temporary.
Old Oct 9, 2005 | 01:11 PM
PREDATOR-Z's Avatar
You have 2 choices if you want to use notched heads.
1- Fill in the notches
2- Run notched gaskets.
Being you have a 6.0, option 1 is preferable.
Old Oct 9, 2005 | 02:49 PM
Taspeed's Avatar
Do they even make notched gaskets?
Old Oct 9, 2005 | 06:07 PM
Brian Tooley Racing's Avatar
Do not use MLS gaskets on heads with notches
Do not weld the notches shut on heads, it removes the heat treat from the heads and then blows gaskets anyway.
Fel Pro makes a 6.0 graphite gasket 9199PT
GM makes a 6.0 graphite gasket 12558936
Hope this helps
Old Oct 10, 2005 | 02:55 AM
PREDATOR-Z's Avatar
Learned something new (filed in archive).
But Brian, if the purpose of the notch was to remove heat, why did they do away with it after 2000?
As far as filling the notches, quite a few members here are running welded up notches with no issues. Of course a bandaged head does have limits.
Old Oct 10, 2005 | 06:26 AM
Taspeed's Avatar
Hope this helps
whew...I knew if I wished hard enough there would be a simple solution. Now if I could only wish the car back together on its own. 1 year 11 months later ...
