LSK Lobes: Are they making more power?
Originally Posted by MARKSZ71
i have one of these new cams in my car, gomer just installed i will have some results pretty soon on my 347 i think the lift is around 640
We have consistently seen with HYDRAULIC ROLLER cams with faster ramp speed, higher lift cams make less power everywhere and float the valves sooner. One of the most powerful N/A Ford 306 cu in cars on my dyno would turn 8000 RPM with factory unmodified lifters, the lobes used were the BBC Extreme Marine low lift. I challenge you to find a slower lobe then those, when we put in faster ramp lobes the car made less power everywhere and floated the valves 1000 RPM sooner. The spring pressure was 180 seat 400 open. With good heads, fast ramp rates are not the answer. We have also seen lower lift lobes (.580") make more power then some of the higher lift lobes (+.600"), not to mention how much easier the lower lift stuff is on parts.
With 110LSA the Power band is not going to be as wide.
Therefore like Mssingkid said he going to have to sift sooner.
6300 sounds right, but then I dont know. I like to REV high to make power.
I belive Brian Tooly is right. Faster lobes are not the answer.
Fast lobes give you better cylinder pressure so the the troq hit sooner (only 300RPMs)
advertise DUR DUR@.050" lift Lift 1.7 rocker
273 224 .581
268 224 .581
The 268 will have better idle quality and better low end troq (not much)
so I see why people like fast ramps
But fast ramps do float valves
we need REV-Kits baddly
I like to REV REV high or dont REV at all
Higher REVs make more power
(of coarse right cam, good flowing intake, heads, exhast)
273 224 .581
268 224 .581
LS1 Tech Administrator
273 224 .581
268 224 .581
273 224 .581
268 224 .581
Of course, it may just be that the AFR 225 heads are so good.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Thats true. AFR heads are the best. But you said LSK lobes are not fast ramp lobes when you compare them to XE-R.
The LSK has faster ramps. Faster then XE-R Bro.
I like Hyraulic Roller Lifter Cams. I thought XE-R were the most aggressive HR cam lobes when it first came out. Then I saw the LSK lobes and I said dang thats almost like a solid roller.
We know you have a good set-up. AFR heads, and good spring pressure.
We know also that the LS1 is has a bigger base circle than the LT1, and all 1st gen SB Chevy, they are in the same family, just like LS1 and LS2
Fords OVH engines also have a small base circle. So they Float Valves sooner then the LS1.
Brain Tooly and I were talking about cams in general.
and Yes 110LSA has a narrower power band than a cam with 114LSA
__________________
Originally Posted by Brian Tooley
We have consistently seen with HYDRAULIC ROLLER cams with faster ramp speed, higher lift cams make less power everywhere.
I should have results from a AFR 225 headed 402 LS2 with LSK intake & XER exhaust in the next few weeks. Trying to give the intake a little kick in the ***!
Thank you to bring your lights in this thread LSX-Racer.
I guess your comments are based on experience, tests and engine build....
Question:
Is it possible that some Heads could like the extra lift and some others could just choke with it???
Btw awesome nice pics in your sig !!
Christian
Question:
Christian
#32
Originally Posted by Patrick G
If not the best, certainly up there. No, I made mention that the LSK lobes are slower than the XE-R lobes from .006" to .050", but faster from .050" to .200". This faster ramp after .050" along with an arc that better follows the momentum of the lifter (which wants to loft) is one of the breakthroughs that allow the LSKs to work better than the XE-rs.
After .050" yes, from .006" to .050" it's slower than the XE-R. The duration from .050" to .050" is what really determines how aggressive a cam is anyway and in this area, the LSK is much more aggressive than the XE-R and one of the big reasons why it makes more power. The softer ramps from .006" to .050" lower the tendancy for the valves to bounce on the seat.
I thought that too. That's why I'm running them and have been for over a year!
Agreed.
Not necessarily. It's all about proper valve events. A 114LSA cam with overlap biased to the exhaust side of TDC is probably not going to have as broad a power band as a 110LSA cam with overlap centered over TDC (like my cam). If you ever look at my dyno sheets, you'll see lots of power down low and up high. It's very balanced. Not what most people would expect from a 110LSA cam. But then again, too many people on this board are brainwashed into believing that only a wide LSA cam can make broad power. It's all about selecting the proper valve events and overlap.
Agreed.
So the the more aggressive nose doesnt really contribute to more valve float.
So its from the seat to .050
I always thought that it was the bigger the nose, the more valve float you get
and also more valve chatter
I learn something new every day
#33
Originally Posted by Originally Posted by Patrick G
Too many people on this board are brainwashed into believing that only a wide LSA cam can make broad power. It's all about selecting the proper valve events and overlap.
AMEN TO THAT
#34
Originally Posted by Jason 98 TA
I've been putting together some heads cam packages with the LSK lobes I'm currently looking for someone wanting to be a test car for the heads cam package
#35
Originally Posted by JMBLOWNWS6
How about we make my car a tester with the LQ9 heads and a TSP blower cam Im putting it back together starting Thursday night
__________________
#36
If you look closely, Jason made that offer in October of last year. He's probably on to 10 different projects since then.
#37
#38
Did you have to notch the pistons with that cam? Are you running stock bottom end(346 stock stock)? And Compcams make that cam right?
__________________
