LS1 Question.
Here are the details:
Stock LS1 heads
Stock LS6 intake
K&N CAI
Z06 MAF
MTI Ported 75mm TB
SW 1-3/4" LTs with hi-flo cats
SW catback
NGK TR55 Plugs
ASP Underdrive Pulley
cam - .608/.612 238/242 115LSA
REV Springs
Hardened Pushrods
LS1 Edit dyno tune
Best Mustang Dyno was 333rwhp
Another friend has another 2004 GTO 6-speed with the exact same list with the exception of Kooks 1-7/8" LTs with hi-flo cats and Corsa catback. His Mustang dyno (on the same dyno on the same day with the cars both cold) was 380rwhp. I cannot believe that the different primary size of headers and the different catback made 47rwhp difference!
The most timing that could be put in the 333rwhp car because of detonation was 26 degrees as opposed to 29 degrees for the 380rwhp car.
The 333rwhp car traps 106 and the 380rwhp car traps 111.....Hell, the 380rwhp car trapped 105 bone stock!!!
Any ideas??? Its a hell of a puzzle to me.
EDIT- something else.....we had a dyno day in February, all of the GTOs that showed were stock from our group, including both of the aforementioned cars, the car that is now dynoing lower actually was the highest stock dyno at that time.
Stock LS1 heads
Stock LS6 intake
K&N CAI
Z06 MAF
MTI Ported 75mm TB
SW catback
NGK TR55 Plugs
REV Springs
Hardened Pushrods
LS1 Edit dyno tune by HPE
My new tuner found timing to be low, around 23* from my GP tune.
He uses HP tuners.
If that does not get you another 30-40 HP (I think it will) I'd suggest changing the cam to something with a bit more intake duration and less exhaust duration. Its been years, but I saw this happen on carburated street race engines in the late 70s - if you had really good of headers, etc., buta near stock or small intake manifold, and some overlap combined with a big exhaust duration and lift, it would scavenge some intake charge traveling out the exhaust at some RPMs. I would think a modern engine, or the dyno sensers, would pick this up, but . . . .
IF the cam is made to spec degreeing won't do anything. But my son and I got a cam from a respectable name brand through a good retailer about two years ago for the stock block in our 98 Z28: the thing ran like a pig and we struggled for weeks before finally deciding to have a shop check the cam: sure enough, it five degrees off. In fact we were ultimately convinced it was not even the advertised lift: just some screw up somewhere. We were just glad that it had not resulted in any valve-poiston clearance problems.
The retailer replaced it no questions asked and we degreed it putting it in and had just what we expected after that.
Chuck
Chuck
I picked up 35 rwhp (425 to 460) going from SLP LT's and an LS6 intake to QTP HVMC LT's and a FAST 90 (purchased FAST intake from HPE actually), so I know what a good header can do, but he GTO in question just seams weak. Seems like cam is off or your Mustang dyno is damn stingy- but then again, his MPH sucks.
There is definitely a performance difference between the various headers out there and the Kooks are superior IMHO.
I would have never guessed it, but I have seen similiar results from others since I installed mine.
My guess is that the headers are making the difference. There's one way to find out
Good luck to ya!
