Help Please Question bout buying cams
You may want to add new valve stem seals and titanium retainers, or need new seats, depending the springs you choose.
Basic Camshaft Bolt & Gasket Kit Includes GM Timing Cover Gasket, GM Timing Cover Seal, GM Water Pump Gaskets, GM Harmonic Balancer Bolt $43.99 '
with this will i be set or what else do you think i need?
