Anyone bought this 402
I wouldn't trust that shortblock as far as you could throw it.
Scoggin-Dickey, Texas Speed, or Speed Inc. offer some pretty bad *** combos!
You should see if you can get ahold of the GM High-Tech Performance magazine July/August Issue 2005. It has 15 or so short-blocks for under 5 grand, and all the specs.
*LS2 aluminum block
*Eagle 4.000 stroke crank
*Scat H beam 6.125 rods
*Diamond -14cc dish or -2cc flat top pistons
*Diamond plasma moly file fit rings
*Clevite rod and main bearings
*Durabond cam bearings
**Balanced and assembled**
We also install in each short block all dowel pins, and oil/coolant plugs. In the custom built crate you will also find the LS2 front cover, timming set, and valley cover. Ready to ship price is $4,095.00 + freight. We have upgrades available also. Let me know if I can help!!
I believe that Thunder Racing has a package as well...but by the looks of it I think that you already have some info on the SDPC 402 LS2...
They won't back something as simple as an oil pump....couldn't imagine the hell it would be to try to get any help with a motor.
Chuck
Give these guys a call. Good shop, and good people.
I got mine from TSP for $3800. Mine is an LQ9 block with an upgrade to Lunati Pro Mod rods.
We have been selling LS2 402 shortblocks like crazy lately and have been seeing some excellent results!! Shoot me a PM and with your email address and I can get you a full estimate and itemized list with all the parts included.
-Zach
knock sensors location
lifter trays
timing chain
grind one side of block for motor mounts
put washers in windage tray to clear crank shaft bolts
and head studs.
I got my motor from SDPC and they give you most of what you will need.
I just got my car tuned and dynoed 450 rwhp 470 rwtq I used my old heads and intake and have a very small cam for Ca. smog.
I wouldn't and won't buy a thing from SLP ever. All of my interaction from them when I started modding was mediocre at best and ever since then my business has been with TSP who have taken excellent care of me everytime with no problems, issues, or complaints.
