oil pump costs??
stock ls1
ls6
ported ls6
Wanna see if i can afford it since i pulling it to replace my ls1 chain with a ls2
Ported ones range in the $120>130
in regard to the oil pump go to the nearest dealer (let them take the shipping cost), buy whatever pump they have (new stock of course) port it yourself, and shim it with two 50 cents SS washers, also you have to buy some locktite, some sealant, A SHIM GAGE, you need to center the snout of the crank to the pump center!
A NEW pulley bolt.
THE MOST IMPORTANT: goto ebay and find this two books about hi perf LS1-6 theyre easy to locate, I`m also building a my engine on crum budget and the books are the BEST EVER MOST BANK FOR THE BUCK I ever spended, exellent info. They let you enjoy this forum ans no one can
BUY THE TWO BOOKS BEFORE ANYTHING ELSE!!!!!!!!!!!!!!
GOOD LUCK!
both on my car and others. Im not too worried about it being ported or shimmed. I figured the ls6 is better than the ls1 oilpump all together. https://ls1tech.com/forums/showthrea...12#post3650412
Jay
Jay
