2001 Stock Heads Adequate For Comp 212/218 .522/.529 Cam
Old 10-25-2005, 02:10 PM
amit's Avatar
Originally Posted by glennhl
I think a 224 is the smallest cam you should put in an Fbody LS1. 112 LSA for a 6 speed, 114 LSA for an auto. After a tune, my 224 drives like a stock cam. But it does have a lot more power from 2000 to 6600 rpm!
bingo.
Old 10-25-2005, 03:11 PM
glennhl's Avatar
Originally Posted by JS
I have alittle info
I had a 218-224 527-535 114+4 I used to shift at 6200,it ran 11.70's@114
Threw a set of S1 heads on the car and went 11.40's@117
U DONT NEED TO SHIFT AT 6500
My new GTO has a very small cam
214-222 559-566 115+4...It was put in becuase I wanted a cam designed for shorties (standard split) that sounded stock but pulled hard to 6500 w/good lowend..
I shift it at 6300 w/the rev limiter set at 6500..
I will be adding either a blower or a good set of heads to my GTO over the winter....
I also had 2 versions of the TR224
It doesnt sound stock...
This is excellent information. I'm impressed with your times and speeds with the small of cam and shifting that low!
Old 10-25-2005, 09:22 PM
Pontiacerator
RevGTO's Avatar
Why would you want to peak that low? Put in the 224 and reprogram your auto to shift around 6500. These engines love to rev!
This explains it ...
Originally Posted by Patrick G
The biggest killer of 4L60Es is not the power, but the rpm. Anything over 6000rpm will dramatically shorten tranny life...that's a fact. That said, a good converter with at least 3500 stall that keeps your power above 4500 (in shift extension) is a wise choice. This will keep you from having to rev it to 6500+ every time. Selecting a cam that make peak power closer to 6000 is a smart move for long trans life and best power in an A4.
Old 10-25-2005, 09:29 PM
mrr23's Avatar
Originally Posted by Ragtop 99
BTW, I think Vinci has a 212/218 112 cam that I would look at if you really want to stay in that duration. It has a bit more lift and overlap and will make more power than the comp with little or no negative effect in drivability.
there are two. 047 cam 210/218 .531/.531 112LSA and the 062 cam 210/218 .551/.551 112LSA. just put the 062 in the wifes car two weeks ago. hoping for some dyno time before friday. it'll be at the track on friday, regardless of dyno time.
Old 10-25-2005, 09:55 PM
zspot98's Avatar
You might want to look into getting some hardend pushrods also. Don't think the stockers will last too long, if at all.
Quick Reply: 2001 Stock Heads Adequate For Comp 212/218 .522/.529 Cam
