Can someone please help!!!!!!
Old Oct 25, 2005 | 07:30 AM
n20stroker's Avatar
Default Can someone please help!!!!!!
Just finished my 402 with iron block. not happy with track times.
im running gtp stage 2 heads,trex cam,comp roller rockers ls6 intake ported tb, 4.10 gears with cartech clutch set up and old tune from east side for my 382 with same cam and heads.
best pass at the track was 11.85 at 121mpg with a 1.75 60ft
i recorded a run my 02s are a 900mv at wide open with no knock.
what should that motor make any ideas. all input would be helpfull( also have a 180 dry kit im going to use after the motor makes good power on motor) thanxs
Old Oct 25, 2005 | 07:36 AM
ls1wannabe's Avatar
first i would say go with a port matched 90/90 for some better numbers also do you have a pulley, from what i have seen most properly built 402 usally make anywhere from 435 to 500 rwhp on motor, a new tune might not be a bad idea either
Old Oct 25, 2005 | 08:25 AM
n20stroker's Avatar
no pully, was going to invest in the fast intake and nick williams tb. motor is built strong, good oil pressure. a tune would def help thanxs
Old Oct 25, 2005 | 08:12 PM
SUX2BU's Avatar
tune, pulley, 90/90.
List ALL your mods. i didn't see headers or x pipe.
whats your race weight too?
Old Oct 25, 2005 | 10:17 PM
Turo's Avatar
Originally Posted by n20stroker
... 11.85 at 121mpg...
121mpg?
Old Oct 26, 2005 | 07:10 AM
n20stroker's Avatar
mods, gtp heads,trex cam, flp long tubes with no cats,qtp cutout, 180 dry shot, no a/c, ls6 intake with ported tb callies crank, mahle pistons, eagle rods and comp rockers. soo far best et at track 11.8 at 121mph on motor oh ya stock 10 bolt 4.10 gears
Old Oct 26, 2005 | 05:52 PM
SUX2BU's Avatar
weight?
Old Oct 26, 2005 | 06:35 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Something doesn't make since. The 60fts are weak , but I do understand since you are on the stock 10 bolt. 1.5 60fts would knock 4/10 off, but the MPG...I mean MPH is still way low for that set up.
Just for grins, go have someone push the throttle to the floor (with the motor off of course) and see if you are getting a full wot travel.
You need to get a good tune any way to make sure the changes are made to accomodate the new cylinder volume. The PCM still thinks you are running a 346 and there's a chance your injectors are pegged out and not providing the amount of fuel the big motor wants. I would fix these things before considering a 90/90 set up. I'd also invest in a solid rear unit before the 90/90.
How heavy is the car?
Old Oct 26, 2005 | 08:03 PM
dame's Avatar
did anyone consider he might be choking that big motor with those heads (that were made for a smaller bore)
Old Oct 26, 2005 | 10:19 PM
SUX2BU's Avatar
have you dynoed it yet?
Old Oct 28, 2005 | 03:07 PM
n20stroker's Avatar
the tune in the car now is for 382.went to the track the other nite, just for the hell of it i sprayed 100 shot 60ft 1.62, 1/8 7.3 at 95 and 1/4 11.52at 121. dont know why my mph was the same. car ia full weight with light weight cage. the messed up part is that my stock 346 with stock z06 head and 218/224 cam on 125 shot went 10.97 at 128. going to do a leakdown test see whats up
