what size rod to hold up the lifters??
5/16" wooden dowl cut 4 inches longer than a cam. Pull the cam retainer plate off an there will be a hole on each side of the cam.. just slide those babies in there, one for each side... works wonderfully.
I think a 5/16 rod, about 24 in and the two small holes. One on each side of the cam. I would double check the length before you cut the rod. I just done one. Take all the precautions. I dropped a lifter. Not fun at all. A 9 hour job turn into a 24 hour job. Had pull the head drop the pan and lift the motor.
5/16 brake line! Cheap and easy to make special tool. I ovaled the line a little in a vice, and bent a handle into the line so I could wedge the lifters in there bores. Make a point at one end with a hammer and make them a few inches longer than the cam.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
The rod doesn't hold up the lifters, it prevents them from falling all the way out. Not sure about 1/4", it may be too small. When my 5/16th steel rods were in place, I looked around with a boroscope (2002 motor) and 5/16 looked like it would just catch them if they started to slide.
Let me know what you all think ?
![](https://cimg6.ibsrv.net/gimg/ls1tech.com-vbulletin/2000x1504/002f148d_c46f_48b7_91cf_5441edb3357b_fe7b10d67454b1fc3fe566bd30f03c5cc97cab11.jpeg)
Have you tried pushing inward on the rod whilst you spin the cam? The cam might lift the lifter up and allow the rod to go in if you are applying pressure at the same time.
The following users liked this post:
G Atsma (10-31-2021)
