Looking for bore thickness (ls6 / ls1)
Old Oct 27, 2005 | 01:02 PM
bayer-z28's Avatar
Default Looking for bore thickness (ls6 / ls1)
I thought I have read somewhere that the LS1 block cannot be bored due to thin CYL walls. If you'd like to bore the block you need a ls6 or C5R block?
Anyone have the specs for the cyl wall thickness on these two engines.
I tried Googling and searching on here, but to no avail.. Looking for a comparison.. I
Thanx in advance!
Old Oct 27, 2005 | 01:33 PM
xfactor_pitbulls's Avatar
Thanx in advance!
Search alittle, but the jist is this. A 6.0 steel block be bored to AROUND 4.040 from the stock 4.00. It is the ONLY block that can be bored for any more than .008-.01. An LSX based aluminum block has to be resleeved for extra bore. The C5-R comes with a 4.125" bore standard.
Brandon
Old Oct 27, 2005 | 01:51 PM
ROCNDAV's Avatar
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/213148-jrp-s-faq-commonly-asked-questions.html
Also search for bore in this forum this has been asked a bunch of times.
