Too much oil?
Old Oct 28, 2005 | 06:07 PM
black99ssm6's Avatar
Default Too much oil?
I got the oil changed the other day and i told the guy 5.5 quarts but obviously he didn't get it and put 6 full quarts in. Do I need to drain some out or is it ok?
Thanks in advance
Old Oct 28, 2005 | 06:11 PM
jimz's Avatar
six is fine
some autocrossers put in seven
Old Oct 28, 2005 | 06:14 PM
thanks man just wanted to make sure
Old Oct 28, 2005 | 06:54 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
Yeah I run 6 every time I change my oil. It tends to slosh around in the oil pan, especially on a road course. There have been some proven oil starvation problems, mostly concerning the deisgn of the oil pan.
That's why as posted above, most people on the track run 7 qts.
Anyways, you'll have no problems running 6.
Old Oct 28, 2005 | 07:00 PM
Lithium's Avatar
SSU's Drunk Typing Whore
I would run a bigger oil filter with 6 quarts. Part number 2006 I believe (k&n)
Old Oct 28, 2005 | 07:09 PM
BMW ///M Nerd
No need to really. The pan is plenty big to run 6qts with a regular filter.
I just switched over to the K&N 2006 my last oil change.
You can run 6 qts. with either filter, NO problem at all.
Old Oct 28, 2005 | 07:53 PM
REDWS6ROCKET's Avatar
i always run 6qts with a pf46. you have an ls1 it will use a little oil any way
Old Oct 28, 2005 | 11:45 PM
BriancWS6's Avatar
6 qts with a K&N HP2006 filter here as well.
Old Oct 29, 2005 | 05:15 AM
Patman's Avatar
It's been proven that based on the size of the oil pan on the LS1 f-body, that you can safely run up to an extra 1.5 quarts if you wish. I run an extra quart on my C5 (I run 7.5)
Old Oct 29, 2005 | 08:32 AM
Luna's Avatar
I put 6 in mine and my friends thought I was nuts, but it runs fine and I find that its right were it should be by the time I need to change the oil again since the LS1s tend to burn a little oil
Old Oct 30, 2005 | 02:14 AM
Var's Avatar
Var
7 quarts in my Z06 with mobil one extra capacity filter
Old Oct 30, 2005 | 06:11 PM
Camaro99SS's Avatar
K@N 2006 filter (the taller one) with 6qts. I've never tried 7, but I'd be leary of the crank spraying that extra quart everywhere and creating air bubbles in the oil. Maybe someone on here with experience can chime in on that one.
Jason
Old Oct 31, 2005 | 10:36 AM
SSCamaro99_3's Avatar
The GM Manual for my Dad's 2004 Sierra specs 6 quarts for an oil change. I run between 6.25-6.5 in my F-body with the long filter.
