Newbie Question
Old Oct 29, 2005 | 11:34 AM
hotrodrx7's Avatar
Default Newbie Question
I am swapping cams and heads on a 2001 LS1 motor. Going with a Futral F11-114 , LS6 heads milled .030" and Cometic .045 gaskets. I don't anticipate any P to V clearance problems but want to check it anyway. What kind of clay should I use on the pistons?
TIA
Old Oct 29, 2005 | 03:25 PM
PREDATOR-Z's Avatar
Use a dial indicator, not clay.
Old Oct 29, 2005 | 04:34 PM
hotrodrx7's Avatar
Well, with a dial indicator I could determine the top of piston location relative to the deck at the point of max valve lift but how do I know the location of the valve lip relative to the deck at the same time? Anyone else? Anyone who has used clay, what kind did you use?
Old Oct 29, 2005 | 05:48 PM
hotrodrx7's Avatar
Found this in a google search:
http://www.valvoline.com/carcare/art...cid=4&scccid=5
