Found out why my motor developed..
Old Oct 31, 2005 | 08:57 AM
Phil99vette's Avatar
7 Second Club
Default Found out why my motor developed..
Since 2 track outtings ago my car developed a valve tick. I didnt really have time to figure it out and I assumed it was a bent valve. Took the engine out and when I removed the valve cover I found 3 rockers has lost their needle bearings. The sides were blownout and the needle bearings were in the oil pan.
Phil
Old Oct 31, 2005 | 09:00 AM
RelentleZ's Avatar
ouch. i had a buddy with a 98 that had the same problem.
Old Oct 31, 2005 | 09:23 AM
LSUxBlake's Avatar
That's strange, I didn't expect Jesel to have that problem.
Old Oct 31, 2005 | 09:29 AM
NOSjohn's Avatar
Restricted User
I believe the Jesels are going in his new motor. That is an odd situation but everything has it's breaking/failure point.
7 Second Club
This was my old motor with the factory rockers.
Phil
Old Oct 31, 2005 | 09:34 AM
LSUxBlake's Avatar
Phil
ok, makes a bit more sense to me now
Old Oct 31, 2005 | 10:02 AM
SAM98WS6's Avatar
wow..never heard stock rockers doing that before..sorry to hear.
Old Oct 31, 2005 | 10:13 AM
TAQuickness's Avatar
Old Oct 31, 2005 | 10:29 AM
7 Second Club
I guess stock rockers, 7000+ rpm and XER lobes don't mix.
Phil
Old Oct 31, 2005 | 10:35 AM
NOSjohn's Avatar
Restricted User
Yes but you've had them on there how long? I'd have to say they held up quite well !
Old Oct 31, 2005 | 11:19 AM
7 Second Club
They have less than 2000 miles on them. I have only put 7k on the car since I have owned it.
Phil
Old Oct 31, 2005 | 11:21 AM
NOSjohn's Avatar
Restricted User
Oh, okay...then yikes !
Old Oct 31, 2005 | 11:23 AM
dug's Avatar
dug
Did anything else get hurt?
Old Oct 31, 2005 | 11:31 AM
7 Second Club
Everything else looks to be ok. cam lobes are fine and the pushrods look good. Can't imagine how much power it was down, it went 10.12 @ 140.1 last time out with a slow 60'.
Phil
Old Oct 31, 2005 | 11:32 AM
Nasty N8's Avatar
And people want to keep the stock rockers in there motors. I have seen it dozens of times.
Nate
Old Oct 31, 2005 | 11:56 AM
98A4LS1's Avatar
Are there any alternatives/options for replacing stock rockers other than expensive aftermarket rocker arms?
Old Oct 31, 2005 | 12:12 PM
SAM98WS6's Avatar
Nate
And there are people here that promote using the stock rockers...
Old Oct 31, 2005 | 12:20 PM
ROCNDAV's Avatar
Yes, get with Nate. He offers a Harland Sharp modification, in which they replace the trunion on your stock rockers. I had it done, although my LS1 isnt finished yet
Old Oct 31, 2005 | 12:31 PM
NOSjohn's Avatar
Restricted User
Yes true but you must realize that Phil is probably pushing 600+ rwhp. IMO, the stockers are good for 400-500 rwhp. If someone isn't pushing those numbers why buy a set of 500 dollar rocker arms?
Old Oct 31, 2005 | 12:35 PM
777's Avatar
777
The needle bearings falling out is a common problem. I'm trying to figure out why power would mean anything for rockers. I would think they would be rpm related.
