Which heads to chose?
Old Oct 31, 2005 | 01:15 PM
krauSS 02's Avatar
Default Which heads to chose?
Hey everyone. i am thinking about putting heads on my car but i am not sure what setup is should go with. Here is what is done to my car: Flp longtube headers, underdrive pulley, tsp 231/237 .598 112lsa. i put down about 420 and i want to break 440 with heads and hit 11.1 comperstion. But i do not want to have to do any piston work. i just want somethin i can throw on. What rand and what stage should i go with? any help is greatly wanted.
Old Nov 1, 2005 | 12:02 AM
krauSS 02's Avatar
anyone have any ideas. Please i need help with this.
Old Nov 1, 2005 | 07:42 AM
Brian Tooley Racing's Avatar
I would go with the new ET 11 degree 215cc head or the new TFS 13.5 degree 215cc head, they should be the most powerful 3.9 bore heads on the market.
Old Nov 1, 2005 | 11:41 AM
cowboysfan's Avatar
look into patriot heads, cant beat them for the price. I'm going for the tsp 231/237 .598/.595 112 lsa w/ pp ls6, stg II, 2.02/1.60 59 cc. should make some awsome HP.
good luck.
fuerzaws6
Old Nov 1, 2005 | 12:18 PM
PREDATOR-Z's Avatar
PRC heads 5.3L, stage 2.5 from TSP.
Old Nov 1, 2005 | 02:04 PM
2000PewterZ28's Avatar
Call TSP,they will take care of you.
Old Nov 1, 2005 | 02:29 PM
Gunnar@Patriot's Avatar
We can do a set of our LS6 style heads with 2.02"/1.57" valves and 59cc chambers that will give you 11-1 compression and still be at factory deck height. These will come with a flow show that is for the heads you buy. They will run $1,195.00 a pair assembled. This includes new GM MLS head gaskets and OEM head bolts.
Old Nov 1, 2005 | 06:13 PM
SS1875's Avatar
Lingenfelter LS6 heads, check them out, they are a sponser.
Old Nov 1, 2005 | 08:23 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
AFR's...
Their design is proven and they make good power on almost every combination they have been bolted on...worth the extra money for the quality and peace of mind.
Are you thoroughly confused yet?....LOL
Seriously, call or PM me if you would like more info.
Tony M.
PS....Regards to all from Vegas....Make sure you stop by the AFR booth if your lucky enough to be attending the show (SEMA of course).
Old Nov 1, 2005 | 08:25 PM
davered00ss's Avatar
Moderator
Another vote for AFR's.
Old Nov 2, 2005 | 06:33 AM
speedracer5532's Avatar
AFR, you won't be disappointed.
Old Nov 2, 2005 | 07:05 AM
SideStep's Avatar
AFRs
Once you have them "that" part of your performance package will be resolved, finished. You can then focus on the other components and not worry about the quality of the heads....
