Thicker Head Gasket, Lower Compression?
Old Oct 31, 2005 | 07:54 PM
HOSS's Avatar
Default Thicker Head Gasket, Lower Compression?
how much could i lower the compression if i got a thicker head gasket? would it be significant and advisable for running boost?
Old Oct 31, 2005 | 08:05 PM
oange ss's Avatar
all depends on what your startin with and compression goals, but yes thicker head gaskets lower compression, but you cant go too thick under boost as the ability of the gasket to hold the pressure diminishes
Old Oct 31, 2005 | 08:08 PM
TAQuickness's Avatar
you are much better off lowering compression with your pistons or combustion chambers.
Old Oct 31, 2005 | 08:43 PM
HOSS's Avatar
great...thanks for the help guys
