Trickflow vs AFR on 3.90 bore flow numbers
#43
Brain, I do not know but plenty of people must by now.
I'll research it.
Actually that might be a bad comparison because it would take much cash, effort and tuning to do an apples to apples with that particular C5, which was built as a showcase for those heads.
Bench racing......
Anyway I am looking forward to what these heads can do !
I'll research it.
Bench racing......
#48
I'll research it.
Bench racing......
I'll research it.
Bench racing......
The heads are being tested on an engine dyno, with Hooker headers and Kooks headers, LS6 and Fast 90/90 intakes both. Right now we have 8 cams ranging from 216/220 to 232/236. Being tuned with DFI, so WOT tuning from cam to cam is a snap.
Whatever makes the most average power is what's going into my C5
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#52
1 Post
Originally Posted by 66deuce
i know i'm going to be in the minority,but something small.like a TR224.
#55
We are still waiting for the dyno numbers, what size cc chambers are available? And will they work with a G5x3-114 cam on a stock LS6 bottom end? I'll be buying a set as soon as they are available.
Thanks,
Al
Thanks,
Al
#56
Originally Posted by equandt
Run them with the TR224 cam. If its going to be a street head, run it with a street cam.
After that you can test them with a 230s cam.
#57
Thanks,
Al
Thanks,
Al
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#58
Originally Posted by Jimmy P
Brian, have you thought of comparing them to the ETP 215 heads? There is a thread in the Dynometer section of them dynoing 20rwhp over the AFR 205's.
