car wont start after cam installl
Originally Posted by distortion_69
Dot to Dot? Think it needs a relearn? What all did you change besides the cam itself? That could give us a little more information about what could go wrong.
Josh
Josh
Originally Posted by 227Hawk
You did line up the retarded mark and the camshaft dot?? I'm asking what mark you
lined up to the camshaft? Stock or retarded keyway?? Should be the one for retarded.
Hawk
Hawk
Originally Posted by pdd
my timing chain had a dot for straight up-then had no shapes to either advace or retard but the instuctions said 'to the right is to retard the cam-to the left is to advance the cam' so i put the crank snout pulley 2 slots to the right to retard the cam. then i lined up the the top gear and the bottom gear the way i would normally-dot to dot
I still think the cam timing is out and you might of done a bunch of damage. I would do a compression test. You have spark and fuel. So the next step is that cam timing is out. let us know. John
hers the way i did it in this pic, the only thing different in this pic my keyway on the crank snout is 2 more slots to the right for 4 degrees retard
http://customrodderweb.com/tech/0506htp_degree_08_z.jpg
There should be an 'A' or triangle for advance
There should br an 'R' or square for retard
these are on the crank gear. You should line these up with the cam gear not the stock mark.
Hawk
Hawk
Originally Posted by PREDATOR-Z
Sounds to me like you retarded the crank but not the cam
so am i suppose to move the cam gear also in relation to how many spots i moved the crank gear? someone must have retarded a cam with a timing chain before.
Bingo!!
well thats my fuckup then i didnt adjust the cam gear ,i only moved the crank gear
guess ill have to rip the bitch apart again
check out this pic
http://support.summitracing.com/scri...ted=1044552136
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
check out this pic
#35
i dont think i could ever deal with a double roller chain! too much confusion with them. Didnt one guy have one side tight and the other was loose and ended up bending all his valves and busting a piston?? not trying to discourage you, but they seem almost more of a hassle to the self installer than a perk
Good Luck getting it take care of!!!
Nino
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Nino
#36
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Agreed, bent valves is highly possible. I would think if you actually retarded the crank in relation to the cam, you might be okay.. so long as it wasn't much.. Might as well do a compression test to be safe.
Peace,
Josh
Peace,
Josh
#38
Originally Posted by jrp
holy clusterfuck batman. no offence but i havent seen anybody have as many problems as you; pinched engine harnesss wire with the tranny, stripped crank, valve timinig off, low dyno results, ect
hope you can finally get things worked out, good luck.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
this is the way im gonna retard the cam and crank
http://support.summitracing.com/scr...ated=1044552136
let me know if you can see anything else i should know
#39
don't feel bad.i have a knack for screwing things up myself,lol.when i put my second set of heads on i got the coil packs on backwards.when i tried to start it,it fired and then went BOOM.right away i realized my mistake and changed them around and all was well.boy did i feel stupid,lol.
#40
SN95 Director
do you have a degree wheel, dial indictator, ect? check out the degree walkthrough in the cam guide for more pics and info.
