best cam with a 3k stall
Old Nov 4, 2005 | 09:38 PM
ls1blazer's Avatar
Default best cam with a 3k stall
best cam with stock 241 heads,manifolds and a 3k stall.
Old Nov 4, 2005 | 09:47 PM
Nate_Taufer's Avatar
224/228 is a proven cam. Plus plenty streetable.
Nate
Old Nov 5, 2005 | 01:28 AM
RollinSScamaro's Avatar
I'd say check out an F11 cam or something in that range from futral..
you should up your stall though! you'll definately end up upgrading that 3000 stall to a 3600+ if you get really into it and get a cam that makes power at higher RPMS!
But i guess there are different routes.. maybe you want low end?
Good luck!
Old Nov 5, 2005 | 04:33 AM
66deuce's Avatar
i run a TR220,II4LSA with a 3000 stall,but i run 3.73 gears as well.very streetable combo that my friends can drive if i'm too drunk to get behind the wheel,lol.with stock gears(3.23)i wouldn't go any bigger than around a 224-228* duration.
Old Nov 5, 2005 | 08:44 AM
blkZ28spt's Avatar
Get headers first. Then your standard TR224 or something similer in size.
You could check out the CheaTR as well, I suppose.
Old Nov 5, 2005 | 10:01 AM
PREDATOR-Z's Avatar
Any 224 or smaller cam, but to maximise that I would get the shift extention range of your verter and match a cam wich power range fits that description.
Old Nov 5, 2005 | 10:04 AM
66deuce's Avatar
yeah,i missed the part about the stock manifolds.if he's going to keep the manifolds,at least get a free flowing 3" catback,along with the CheaterTR or something similar.i bet that would be a fun combo to drive around.
Old Nov 5, 2005 | 05:00 PM
ls1blazer's Avatar
the reason for the manifolds is that I cant use headers ...... Because its in my 02 xtreme blazer.
