Possible Problem??
Old Nov 12, 2005 | 10:47 AM
Brandon Boomhauer's Avatar
autozone is good to find m1 0w40
they usually carry a bunch of odd ball weights and what not for motorcycles
Old Nov 12, 2005 | 12:18 PM
777's Avatar
777
Originally Posted by GreekGator
777, not sure if you tried these places, but ive seen M1 0W40 and the 5W40 at Wal-mart. I went to Autozone the other night and they had the M1 0W40 as well. Just a thought. HTH
None at wal-mart, that is where I go to get my oil. They've got 10w40 but no 0w40
Old Nov 12, 2005 | 12:21 PM
GreekGator's Avatar
hmmm, the Wal-mart here in Gainesville has both the 0 and 5W40. So does the one back home where im from. Does the one near you have 5W40?? Did you ever think of running that?
Old Nov 12, 2005 | 02:38 PM
777's Avatar
777
There are two, I know one of them only has 5w30 and 10w40. The other one had 5w30 and something else, but I don't remember what it was.
Old Nov 12, 2005 | 04:00 PM
GreekGator's Avatar
Well, id give Autozone a shot. i was there a few nights ago, and they had the 0W40.
Old Nov 12, 2005 | 09:59 PM
777's Avatar
777
Well I'll do it next time, I already bought the m1 5w30 and used some of it for the cam. I bought the big 5 qt jugs.
Old Nov 14, 2005 | 07:59 AM
V6 Bird's Avatar
Originally Posted by 777
V6 bird can you stop with the name calling and crap, I didn't do anything to you except point something out in 1 thread that seemed obvious to me. I don't know why you are being so negative. I UNDERSTAND PLUG READINGS. You don't have to act like I'm retarded just because I didn't respond to your post. I made one mistake by saying that I unplugged the injectors (which was the coils) why are you making such a big deal about it. I called you out on working with exhaust because you said you had been making custom exhaust 2 years before you started welding. What was I supposed to think? What would anyone else think. You explained yourself and I read it, I thought that was over with. I really don't know why yall keep bringing up plugs. This is the question at hand
wow..Can I grab you a hanky bro?
Old Nov 14, 2005 | 10:34 AM
GreekGator's Avatar
Hey man, how bout you STFU! We dont need people like you on this board. This site is meant to help people and learning about F-bodies. If you're too smart and since you know everything, we don't need your help.
Old Nov 14, 2005 | 11:42 AM
777's Avatar
777
Wow, I've never seen someone so butt hurt over something before. oh well, I at least tried to resolve it.
Old Nov 14, 2005 | 11:51 AM
V6 Bird's Avatar
Come down to Dallas and STFU me up. I gave excellent information and its more then most will ante up here. We seem to have alot of people spreading false information and i get tired of reading it on a board that is supposedly full of technical infortion. If you cant stand it or dont like what i say. Get over it. You are probably one that is spreading bad information that i dont like to read.
Old Nov 14, 2005 | 11:56 AM
V6 Bird's Avatar
Far from butt hurt youngster.
Old Nov 14, 2005 | 12:14 PM
  #32
777's Avatar
777
That is farthest from the truth. You provided no information but for the simple fact that it's normal for oil to be on the plugs in the back. I asked nothing about reading spark plugs which I already knew about. You gave me no information on the real issue, even after I posted that this is the real question at hand. Which was about the lifters.
Old Nov 14, 2005 | 12:35 PM
  #33
cowboysfan's Avatar
did yoy soak the lifters in oil before installing them? just thinking that could be your culprit as to why the noise. they just need to fill w/oil. I dont know if it would cause damage, but I would hate to remove them again. me, I would put it in the next time to do before basket. good luck 777. dont forget this tid bit on your cam change.
fuerzaws6
Old Nov 14, 2005 | 12:41 PM
  #34
PREDATOR-Z's Avatar
Speaking of tech, can we stick to that?
Otherwise it will be locked, and when 777 finds the solution we will not be able to know what it really was.
  #35
777's Avatar
777
I didn't take the lifters out. I didn't install new ones. I just put some dowels to hold the lifters up and changed the cams. But it was ticking before after I just did a compression check. Then it went away in about a minute. It did the same thing after the cam swap. I'm guessing it's just the lifters pumping up with oil. I don't think it's a big deal.
Old Nov 14, 2005 | 12:44 PM
  #36
777's Avatar
777
I'm pretty sure it's just that the lifters needed to pump up with oil. The lifters probably need replacing, that is why it took longer than normal for them to pump up. They should hold out until I get a new forged motor.
Old Nov 14, 2005 | 12:58 PM
  #37
V6 Bird's Avatar
You havent provided us with any good technical information by you performing a compression test with the coils unplugged...I mean hello????
I serisouly doubt you know how to read spark plugs. BUt lots of people will pretend they know how.
Yes it is possible your lifters have bleed down. You answered that yourself. Washing the cylinders out with gas but no igntion will do that. It'd be wise to change the oil immediately to save the bearings from being washed out. But i suppose you knew that too right?
Old Nov 14, 2005 | 01:12 PM
  #38
777's Avatar
777
Ok, lets look at this.
The compression test was in no way supposed to provide technical information. I didn't even show the results. I was just saying that, so it would help those who actually want to help me diagnose the problem.
http://www.densoiridium.com/howtoreadusedplugs.php It's in the sticky, something most people do not read. I don't see why that's a big deal. I did not know that I needed to change the oil immediatly so I wouldn't wash out the bearings, however it makes sense. Thanks for your second useful thing you have said.
Awaiting comment from V6 Bird on being so incredibly stupid because I did not think about changing the oil immediatly after the compression screw up...
Old Nov 14, 2005 | 01:22 PM
  #39
1CAMWNDR's Avatar
So 777 has the motor ticked any more? I mean, if it was the lifters pumping up with oil I would assume the ticking did not return. If that is the case then all should be good. If not .
How does the new cam sound? I am thinking of a 226° .585" with the same 110° LSA + 4° .
Old Nov 14, 2005 | 01:27 PM
  #40
V6 Bird's Avatar
NO need to comment on it. You already know you are stupid for doing it.
And if you think that link is a good link on reading plugs you've got a lot to learn. Much of which we've already learned you are still wet behing the ears from coming out of mamma.
