Just installed LS6 cam..question
Old Nov 13, 2005 | 07:12 PM
HOSS's Avatar
Default Just installed LS6 cam..question
Wondering what is the highest safe RPM's I can go to. I also have the LS6 springs and retainers, along with chromoly pushrods 7.425. Rev limiter is set at 6600, could it be set at 6800 or 6900?
Old Nov 13, 2005 | 07:15 PM
Xtnct00WS6's Avatar
I'd keep it where it is if I were you. I would guess you start dropping off at 6500ish anyways.
Old Nov 13, 2005 | 08:27 PM
Chris81's Avatar
Mine is set at 6600.. I shift at 6300-6500 and it works great, IMO there is no need for the limiter to be any higher than 6600 with the LS6 cam, it peaks around 6000.
Old Nov 13, 2005 | 08:30 PM
Ryan02SS's Avatar
My old LS6 cam setup peaked around 6050rpms and held flat to 6500rpms. Fell off pretty fast after that. There is no need to shift any higher than 6500rpms.
BTW I was using LS6 springs, Tit Ret & stock pushrods.
Old Nov 13, 2005 | 08:52 PM
HOSS's Avatar
good deal...thanks guys, i was hoping you would say higher, I love the way it sounds up there
Old Nov 13, 2005 | 10:19 PM
ArcticZ28's Avatar
Sounds like someone needs to move to at least a high 230's duration cam then
Old Nov 13, 2005 | 10:49 PM
HOSS's Avatar
haha...i am not doing all that **** again, i wanted it to idle stock like..thats why i went with the cam..with the blower it should make some good power
