What can i expect with these heads
Old Nov 21, 2005 | 10:39 PM
AINT SKEERED's Avatar
Originally Posted by strokedls1
Stick with the stockers. The aftermarket rockers don't increase power and have shown to be a big pain in the ***. Stockers work great. I use them on my 422ci with no issues. Are those a 2.08 1.60 valve combo? How much power you make will come down to total parts combination and the tune. If your doing macs why not just use a full long tube header. Either way it is illegal in cali.
Is there any valid hp gains with long tubes over macs that are for real? On a stock cubed car , are the long tube going to make more hp and tq or just top end hp?
Old Nov 21, 2005 | 10:54 PM
Kens_02SS's Avatar
Originally Posted by Richard@WCCH
I'd like to see your results. Could you please post any relavent info for us when you can? Also, feel free to call us at the shop if you have any questions about your setup.
Richard
Still just wondering Richard what size head gasket to run with these heads. They're milled .030 in order to run 91 octane
Old Nov 22, 2005 | 03:00 AM
strokedls1's Avatar
Long tubes from any of the better companies will put down more power accross the entire rpm band over macs. It is like shifting the whole dyno graph up. There is a reason why you never hear about those with all the great long tubes out these days. Ground clearance was the reason to use them in the past.
Old Nov 22, 2005 | 12:38 PM
Richard@WCCH's Avatar
As I recall, the chambers finished off at 61cc. That will get your c/r close to 11.0:1. I would suggest running a stock thickness gasket. The factory mls gaskets would work well in this case.
Good luck.
Richard
