ET Heads info, thoughts, pics, numbers
Valves measured out at 2.08/1.60
Installed height on intake checked out to 1.80 exactly
Spring pressures checked out
140#s at 1.800
375#s at 1.200
404#s at 1.150
Will be checking free drop clearence on a few cams, probably vs stock heads as well. Should be getting flow numbers on a 4.00 bore, and hopefully a 3.90 bore if I can get one fabbed in time.
Build quality is SICK, each head is 9.8 lbs heavier then a stock head.
Steel inserts for the head bolts, nice even clamping force across the deck (which is extremely thick compared to stock)PICs should be coming shortly just have to get them off the camera.
From their site :
Cylinder Head: G III LS1 11° Application: Street / Race
Port Volume: 225cc Chamber Volume: 35cc to 72cc
Test Bore: 4.000" Test Pressure: 28.00" Water
Intake Valve: 2.080" Exhaust Valve: 1.570"
Valve Lift Intake Exhaust Valve Lift
.100" 71 57 .100"
.200" 153 114 .200"
.300" 208 164 .300"
.400" 265 204 .400"
.500" 308 224 .500"
.550" 320 228 .550"
.600" 328 231 .600"
.650" 332 234 .650"
.700" 320 236 .700"
Exhaust to Intake Flow Ratio 73%
Site->http://www.etheads.com/mainpage.htm
I would recommend the 225s for most street setups with a 402, dont think your going to choke it by any means being as they move more air then 99.999% of LS heads out.
If your looking to put together a max effort street setup then I might recommend a customer go with the 240s
When's it headin to the dyno? I wanna be there for that. Let me know.
Will be looking for your results.
Brandon
