Teaser PICs!!! 427ci. LS1 Build
- Katech Resleeved LS1 Block, 4.125" Finished Bore, Seasoned, Vaccum Impregnated, Clearenced
- Eagle 4340 Forged/Heat Treated 4.00" Stroke Crankshaft
- Lunati Pro-Mod 4340 Rods, 6.125"
- Diamond Custom Forged Aluminum Pistons, -10cc Dish w/ Valve Reliefs
- Diamond Piston Rings
- Clevite Main Bearings
- Federal Mogul Connecting Rod Bearings
- Katech Main Caps
- ARP Main Studs
- ARP Connecting Rod Bolts
- GM LS7 Heads, milled .030
- Ferrea Stainless Valves
- Patriot Performance Gold Dual Valve Springs
- Patriot Performance Titanium Retainers
- ARP Head Studs
- Comp-R or Morel Lifters
- Thunder Racing Hardened Chrome-Moly Pushrods
- Ported LS6 Oil Pump
- Rollermaster Heat-Treated Double Roller Timing Set
- Cam = 25x/25x Duration, 0.6xx Lift, 112 LSA
- GM LS7 Composite Intake Manifold
- GM LS7 Fuel Rails
- Cometic MLS Head Gaskets
- LS6 PCV Conversion
- 11.5:1 Compression Ratio Goal
Yeah right...
I left the crank in the bag so it wouldn't rust as it sat in the garage.
It is a dry sleeve block. I am hoping I won't have any coolant issues with it. We will have to wait and see I guess.
Kinda looks like Jerami is stealing some of my ideas.
Cranks and cams are NEVER stored laying down for a reason!
Is anyone else doing a simmilar setup?
Jason
. i take it you said **** smog? im building up a 454 h/c w/ STS setup next year myself. all smog legal.
