Which heads with MTI Stealth II cam???
Old Nov 27, 2005 | 07:19 PM
02NBMFormula's Avatar
Default Which heads with MTI Stealth II cam???
i am trying to decide which heads to get for my formula. it will have kooks headers with a catted Y, MTI stealth cam II and the other stuff listed in my sig. im leaning towards the patriot performance LS6 heads right not but dont now how well they match this cam. also, would bumping up compression to 10.5-1 or 11-1 produce much power??? what are the risk envolved with this??? i always use 93 octane. this is my d/d also if that helps. thanks in advance!
Old Nov 27, 2005 | 08:53 PM
equandt's Avatar
I'm going to go out on a limb and suggest the MTI 2E heads to run with the MTI stealth cam. Compression in the 10.5 to 11.2 range will be good.
You might look at a set of matching 5.3 heads or have the 2E's milled.
Old Nov 28, 2005 | 06:18 AM
PREDATOR-Z's Avatar
I've used that cam in various combinations, best combo I've used was 11.0:1 SCR +, non restrictive exhaust and 5.3L ported heads (2.04/1.585).
Shift points at 6600, limiter at 6900.
Old Nov 28, 2005 | 12:14 PM
predator, do you have any dyno graphs or track times???? also what brand of heads did you use???
