Patriot gold with trex question..
Old 11-29-2005, 07:37 PM
Josh's Avatar
What effect would improper seat pressure and coil bind have on the performance of the car? I've been running unshimmed Patriot Gold's for nearly two years now without any mechanical problems, but the car has consistently dynoed lower than most other M6 T-ReX cars I've seen, despite having a "normal" powerband.
Josh
Old 11-29-2005, 07:44 PM
Geoff's Avatar
Josh
Usually it will cause premature valve float. I have seen cases however of weak springs killing power overall.
Old 11-29-2005, 08:00 PM
Josh's Avatar
Sorry, I'm not trying to hijack the thread, I imagine this is related though. As far as valvefloat, I didn't see any on the dyno.
Could this be a case of weak springs killing power?
Josh
Old 11-29-2005, 08:44 PM
Lady Redhawk's Avatar
Location: sojourning....looking for my city whose builder and maker is God.
Josh
Josh, you had a little bit of that same "gap" in your dyno chart that Allen had. He also has the T-Rex cam, I wonder if he is using the same springs without shims as well.
Old 11-29-2005, 08:54 PM
Josh's Avatar
It would be interesting to know. Of course, he probably could've made 15-20 more RWHP with a cutout, putting him pretty much at the "norm" for the cam.
Josh
Old 11-29-2005, 08:56 PM
NX_CaGEdApE00's Avatar
so .075 shim is what i should run correct on all springs, under the seat...... all agreed....
thanks geoff im not sure who i talked to.. no name was spoken.....
Old 11-29-2005, 09:18 PM
Geoff's Avatar
To do a first class job you should measure each spring. This will take a while, but that way if you possibly have a spring that is out of spec you will be able to catch it before installing it on your motor. You also need to check the install height on each valve, especially if any work has been done to the heads. If for some reason one valve is sitting at a different height in the head then you would need to shim accordingly.
Old 11-30-2005, 12:07 AM
thanks again geoff.. i appreciate everyones help...
Old 11-30-2005, 04:50 PM
stevemilz's Avatar
The T-Rex is a Ruthless cam
Old 11-30-2005, 07:01 PM
got the springs...
installed
135@1.800"
Open
350@1.150"
Coil Bind
.710" lift/ 1.090"
How do i calculate this... since it states .710 lift???
Old 11-30-2005, 07:34 PM
01350ss's Avatar
so did you use shims? which ones?
Old 11-30-2005, 07:57 PM
  #32
no that is just the specs on my sheet...
they differ??? Still confused..... Damnit i dont wanna mess this install up..
sorry for all the questions
Old 11-30-2005, 08:11 PM
  #33
Geoff's Avatar
got the springs...
installed
135@1.800"
Open
350@1.150"
Coil Bind
.710" lift/ 1.090"
Install Height=1.800"
Bind Height= 1.090"
1.800-1.090=.710"
We want to shim .050" from the bind height or 1.090+.050 or 1.140".
So if you are running a cam with .600" of lift you would want your install height to be 1.140"+.600" or 1.740". If your install height is 1.800" without shims you would need .060" of shim. Remember: Measure carefully.
Old 11-30-2005, 08:22 PM
  #34
thanks a bunch... Now i truly understand>>>>>
Old 11-30-2005, 08:33 PM
  #35
...with cheese.
Armageddon's Avatar
i installed a TRex on an M6 car with unshimmed patriot golds. Car made 422rwhp through factory exhaust. I just figured I'd throw that on the table.
Old 11-30-2005, 08:48 PM
  #36
im gonna shim em.... its the right thing to do...
Old 11-30-2005, 08:54 PM
  #37
01350ss's Avatar
so if the trex is .608/.612 he would need .052"/.048" (respectively) shims?
Old 11-30-2005, 08:56 PM
  #38
mine is .609/ .615....
so in reality .069"/.075"
ill probably do .075" all around.... but we will see how it measures
Old 11-30-2005, 10:40 PM
  #39
Geoff's Avatar
135@1.800"
Open
350@1.150"
Coil Bind
.710" lift/ 1.090"
1.090" + .050"= 1.140"
1.140" + .609"= 1.749"
If you start off with 1.800" of install height with no shims you will need .051". You will probably wind up with slightly more (say .060") because you will probably never see the full lift at the valve anyways.
Old 11-30-2005, 11:35 PM
  #40
thanks for clarifying.. great help......
how do i contact u personally in the future geoff..
