Cam possibly kill engine?
Old Nov 29, 2005 | 03:50 PM
SHINER's Avatar
Default Cam possibly kill engine?
I have 131k on my WS6 and I want to put a radical lopey cam will it shorten the life of my engine???
Old Nov 29, 2005 | 03:56 PM
Hennytime's Avatar
id think more the little things that need to be replaced like pumps and such, but if its installed right it shouldnt kill it imo
Old Nov 29, 2005 | 04:13 PM
c0ncEpT's Avatar
if you dont spin to 7K your fine
Old Nov 29, 2005 | 04:35 PM
SUTTERERMAN85's Avatar
yea it really depends on how much more you abuse it with the cam because of how well she runs. but no way it shortens the "life of the engine" you will have to swap valve spings more often and check the valvetrain more often as well.
Old Nov 29, 2005 | 05:13 PM
M6WS6's Avatar
Valvesprings shouldnt even be too much an issue. The only thing that will hurt a motor with a cam swap is how often the pedal hits the floor because of an increase in HP.
Old Nov 29, 2005 | 05:19 PM
luv2spd's Avatar
Radical cams will induce more wear on the engine. Any time you increase hp there is more stress being put to the motor/valvetrain. The biggest reason a cam would damage the motor is the fact that most people will be spinning the motor higher and more often.
Old Nov 29, 2005 | 07:23 PM
SHINER's Avatar
so **** it??....Its not worth it?
Old Nov 29, 2005 | 07:44 PM
styles2769's Avatar
I have 160k on my Z with a cam, the most important thing to know and remeber is keep the motor maintained, make sure whoever does performance work on your motor actually know what there doing, ask question and make sure all the other parts will work in harmany with your new mod. A radical its self isn't going to kill the motor, but if your going to be jumping on the pedal alot then you are going to want to make sure the your valvetrain is staying in tact, every time you change the oil, check the oil for any metal shavings or foreign objects.
Old Nov 30, 2005 | 02:12 AM
ringram's Avatar
Id do a new oil pump, timing set/chain some matching behive springs and light valve gear (Titanium) if possible. Then all should be well as long as the engine is generally sound
Old Nov 30, 2005 | 02:25 AM
luv2spd's Avatar
Yeah, those would all be good things to do. Go for it!
Old Nov 30, 2005 | 05:29 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Do it! Then you can get a stroker in the future!
Old Nov 30, 2005 | 08:59 AM
SHINER's Avatar
i would love a stroker but they are expensive kits ive seen some running for like 4200..not in my wallet...Yall think I should run a TR22 114, or a TR22 112. Something not to drastic that would take it easy on my engine, and has a nice lopey sound?
Old Nov 30, 2005 | 10:02 AM
777's Avatar
777
Get the cam, and get one that you won't have to spin it past 6200rpms. Like mine. It probabyl will peak around 6,000rpms. Either way I won't be shifting much if any past 6000.
Old Nov 30, 2005 | 11:43 AM
SHINER's Avatar
If the lift on the cam is like .560 can i get away with the LS6 spring with the .570 lift limit? Also is a LS1 Hot Cam a good aggressive street cam, or waste of money I have lots of miles on my engine and dont want to be spinning past 5800 with increased power cause I dont know how well my ole engine will hold up...enlighten me please
Old Dec 6, 2005 | 05:33 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
There are better choices out there that will work better performance wise. You could probably go all the way up to 230 and not have any kind of problems. The hot cam still sounds like a monster though, i love it!
Old Dec 6, 2005 | 09:14 AM
GuitsBoy's Avatar
I had some stock lifters go bad on me at 88K miles. I would think about replacing them. I have a feeling my cam contributed to their demise.
Old Dec 6, 2005 | 01:08 PM
SHINER's Avatar
So the hot Cam is nice?, how much hp will be a achieved through the hotcam, its a great price, notice a diff? In sound and perf?
Old Dec 6, 2005 | 03:09 PM
Bigrob339's Avatar
My cam is only a 224/224 dur. with .576/.576 lift cut on a 112, similar to the TR224, my buddy who works at a speed shop had crane cams grind it for him. Its a very nice cam. I only have 25k on my car, the cam went in at 22k. I dont spin my much past 6300rpms and my redline is 6500rpms. I did a katech oil pump, and a double roller timing chain, and some crane valve springs and some titanium retainers. You also might want to purchase some new valve locks also if you do it. Trust me once you have a cam you will love the car even more, more fun to drive!!!
peace rob
Old Dec 10, 2005 | 01:40 PM
SHINER's Avatar
so go with the hotcam? it was like under 500 for the cam springs, and TITANIUM retainers!? on scrogey dickens whateverplace it was sounded like a good deal. I dont have exhaust though, i dont think it ll make aHUGE diff if i had exhaustim saving up for the cam cant afford the exhaust right now..
Old Dec 10, 2005 | 07:53 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Get the cam kit from SDPC www.sdpc2000.com . Then when you get the exhaust it will be that much better in the future! you might see abut 20rwhp out of the hotcam with a few supporting mods, but exhaust is gonna be the must have eventually if you are looking to get something out of that thing.
