Valve spring compressor tool question.
Old Dec 1, 2005 | 05:25 PM
Derek98z's Avatar
crane tool. done over 20 sets of springs. Used the More tool before and broke two of them.
Old Dec 1, 2005 | 08:00 PM
eallanboggs's Avatar
Keep in mind that these heads are aluminum. The studs that hold these tools are steel. You need to be sure that everything is straight, square and flush when pressure is applied to the spring retainer while using these tools. Murphys law applies here as some have done damage to their heads with these tools if they are not used properly. The other option is to use a tool that squeezes the spring directly. This type of tool does not use the aluminum head for leverage which has its' own advantages. If you have sufficient experience you should be OK with the Crane type, but don't leave out consideration of the jaw type.
Old Dec 1, 2005 | 08:40 PM
CBX's Avatar
CBX
Can you recommend one?
Old Dec 2, 2005 | 04:39 PM
Bill Bowling's Avatar
Talking
Originally Posted by Z'mnypit
Do a search on the "Larry tool" then just go make you one like that. It would be the chepaest easiest way.
I did mine with the Larry Tool. $45 each.
Bill
Old Dec 2, 2005 | 06:03 PM
cantdrv65's Avatar
Post
I have used other tools and nothing compares to the ease of the crane tool, and you'll never break it.... I might add its pretty idiot proof, you'd have to almost TRY to mess up your heads.
Old Dec 3, 2005 | 02:47 PM
MetallicaMatt's Avatar
I just made my own Larry Tool, .25" thick Stainless Steel
I think i'm good
just gotta go get a grade 10 bolt
Old Dec 3, 2005 | 02:51 PM
jrp's Avatar
jrp
SN95 Director
another vote for the crane.
Old Dec 4, 2005 | 09:36 AM
2001 SOM WS6 69 GTO's Avatar
Default Tims Valve Spring Tool
Check out our Valve Spring Tool we Sell. Its a third of the price then the Crane and works just like the Crane except you only do 1 spring at a time.
https://ls1tech.com/forums/showthrea...ve+spring+tool
Old Dec 4, 2005 | 10:32 AM
SgtB's Avatar
I used the More tool when I did mine...what a pain in the ***.
I saw an add for the Crane too a week after.....it would have been much easier with that one.
Another vote for Crane!!!
Old Dec 4, 2005 | 01:41 PM
GuitsBoy's Avatar
I just made my own about a half hour ago. Its half crane, half double larry/tim/69gtojudge tool.
Attached Thumbnails Valve spring compressor tool question.-valvespring-tool-001.jpg   Valve spring compressor tool question.-valvespring-tool-002.jpg
Old Dec 4, 2005 | 09:01 PM
SgtB's Avatar
that looks nice. You should patent that and start selling it
