Is the stock flywheel neutral ballanced?
Old Dec 1, 2005 | 05:16 PM
hpcubed's Avatar
Default Is the stock flywheel neutral ballanced?
Installing my 402 which is internally ballanced. Is the stock LS1 flywheel neutral ballanced or do I need to get it ballanced? What about the clutch?
Thanks
Old Dec 1, 2005 | 07:02 PM
tdogg5.3's Avatar
i was also wondering? good question
Old Dec 1, 2005 | 07:17 PM
LS1powerhouse02's Avatar
when i talked to will at centerforce about a new clutch he said the stock flywheel has a zero balance....so i'm guessing that is the same thing as a "neutral balance." Hope this helps!
