Lifter Retainers
Old Dec 3, 2005 | 11:06 PM
Formulized94's Avatar
Default Lifter Retainers
Is there any reason to replace these things? The one i have seem ok, but i do not know what everyone is doing with them? Should I replace them or just reuse?
Old Dec 4, 2005 | 07:44 AM
GuitsBoy's Avatar
depends what you want to do... I chose to replace them just for piece of mind since its only 20 bucks for the set of four. I had a lifter go south, and Im scared to death about turning a liftere sideways. Not that these plastic retainers would make a difference, but new ones couldnt hurt, right? I think most people dont bother replacing them.
Old Dec 4, 2005 | 07:46 AM
vettenuts's Avatar
I am going to replace mine. I think $20 in the overall cost budget is worth it.
Old Dec 4, 2005 | 08:12 AM
CBX's Avatar
CBX
I don't any need to replace them, they don't wear out.
Old Dec 4, 2005 | 09:36 AM
Teutonic Speedracer's Avatar
Some of mine had slop in them allowing them the lifter to rotate 10-15degrees. For $20...it's probably worth it. I upgraded to the LS2 ones and drilled the oil holes in the side (1/4").
Old Dec 4, 2005 | 09:45 AM
CBX's Avatar
CBX
If they are loose then obviously it makes sense. Mine were OK though.
Old Dec 4, 2005 | 11:40 AM
for 20 dollars, why not replace them. I didnt know they were that cheap. What is the deal with the ls2 retainers?
Old Dec 4, 2005 | 01:14 PM
GuitsBoy's Avatar
ls2 retainers work in the ls1, but the ls1 retainers dont fit the tls2 block
Old Dec 4, 2005 | 02:56 PM
ChucksZ06's Avatar
I am building an ls2. Do any of you guys have the part number handy for the ls2 retainers? I would very much appreciate.
Old Dec 4, 2005 | 06:05 PM
to save from haiving any problems i will use the new ls1 retainers. thanks guys
Old Dec 4, 2005 | 09:12 PM
1259365
Old Dec 4, 2005 | 09:53 PM
ChucksZ06's Avatar
Thank you speedracer. Have a nice Christmas.
