how much was your cam intall?
Old 12-07-2005, 02:23 PM
  #41
SmaknaSS's Avatar
I payed $0.00 for labor of H/C and headers.All the work was done myself.
Old 12-07-2005, 03:44 PM
  #42
kpowr82's Avatar
Got the cam/spring package from TSP for ~$700 I think.
Labor (did it myself):
35 gallon Air Compressor $300
625 ft-lb impact $80
Bolt and Gasket Kit $40
valve spring tool $40
threaded rod and washers $15
1/4" brakeline (hold lifters) $8
locktite and fluids ~$50
HPTuners $250 (split it with another guy)
Total: $1483
Didn't need an air compressor (thank God I had one though)
Could have borrowed the impact
Total could have been: $1103
I'm glad I did it myself. I learned a lot doing it, and it made me actually WANT to pull my trans when it went bad. If I had a shop do my cam install it would have cost me $500, I wouldn't have all these useful tools, and I probably would have ended up having a trans shop R&R my tranny for $300.
Cam install ----> Grows bigger ***** to do other work/mods to your car.
Old 12-07-2005, 04:05 PM
  #43
Black Z/28's Avatar
Originally Posted by FUN LS1
Justin, Ask Jason for a pkg price... probably be in the $1300 rang for the works including cam, springs and install, but don't hold him to that... And I'm not sure about the tuning. 'couse $350 for unlimited sounds way cool, I didn't know they offered that. It's a deal for me, since I have several mods coming up that I'd like to know the hp & tq change for.
Does Fbody Central have their own dyno yet? I was up there about a year ago getting a tune and we had use the Dyno over at Heffners to finish up. I'll be heading up there again as soon as I finish with my heads.
Old 12-07-2005, 09:56 PM
  #44
nokeman's Avatar
not that i know of. im pretty sure they take it somewhere else.
Old 12-09-2005, 10:40 AM
  #45
GrannySShifting's Avatar
Thanks for the good word Ed, our dyno should be in the ground around the new year. I watched guys making full 1/4 mile passes on them down in Orlando, so maybe well do some "dyno racing" that every likes to do with the snow on the ground this winter.
We arent far from VA, have 3 VA cars in the shop right now.
Old 12-09-2005, 11:44 AM
  #46
98BirdLS1's Avatar
Just gotta shop around for good deals.
Hotcam: $100 (Used from member)
LS6 Springs; $50 (Used from member)
Misc (Oil, coolant, WP gaskets) $100
Installed myself. Street tuned for $250. So total it was $500.
Now before anyone jumps on my case. I also installed a new timing chain, LS6 oil pump and a bunch of other bolt-ons at the same time, but those things aren't absolutely necessary. I should have done pushrods as well but I went cheap. Inexpirence on my part.
Take my advice, don't cheap out. Replace everything while you're in there even if you have to save for a few more months. I ended up tearing it back down 4 more times because I cheaped out on stuff and runied a cam in the process. I learned from my expirence.
Luke
Old 12-27-2005, 08:52 PM
  #47
LS1SpeedAddict's Avatar
nope, Im not speaking for the shop though just Ive been over there so many times and have never seen one.
Old 12-27-2005, 08:58 PM
  #48
EPP
EPP's Avatar
http://www.exoticperformanceplus.com....php?service=8 Bob
Old 12-28-2005, 12:14 PM
  #49
Bob we charge right there for cam/spring installs as well. Can you hit me with an email sometime? Have a couple ATI questions/comments to run by you Which Mustang dyno do you have?
We are breaking ground to get our 1100 in the groudn right now
Old 12-28-2005, 01:58 PM
  #50
EPP
EPP's Avatar
Our Mustang Chassis Dyno is the 1750. Bob
Old 12-28-2005, 04:39 PM
  #51
$475 for a cam an springs is a good deal, hope I get a deal as good as that when my cam is installed
