Cam Question
Alright, so i have flattop diamond forged pistons (stock CR) with valve reliefs (i think they are -6 or -7cc?). I also have comp 918 springs in for my current cam.
I was looking around at cams and found one that i reaallly like and will probably get. However, i want to make sure i can use this with my current setup, or if ill need to buy heads as well.
the cams specs are:
lift (1.7) .596/.596
duration (@.050) 250/246
My current cam is:
lift (1.7) .597/.565
duration (.050) 230/226
Will this cam work with my stock heads/918 springs?
the cams specs are:
My current cam is:
