3600 enough stall for MS3?
im not too concerned with drivability its basically a weekend/track car.
i'd rather not put in a bigger stall, this one seems to flash higher than 3600 anyway.
TIA
But is the 4000 a serious need? or would it just be optimal? would it stall and buck or something with a too small of a converter?
My advice is, find out what are the shift extentions of your actual stall and get a cam that falls in that range. (A cam that will make maximum power in that range)
Like PREDATOR-Z said, you already have the stall, so save yourself some trouble and pick the cam to match it. Otherwise, you may be disapointed and want to upgrade the stall later, costing you more $$.
