Which H/C combo to go with?
Old Dec 7, 2005 | 10:50 PM
just-a-z's Avatar
Default Which H/C combo to go with?
I have narrowed it down to 3
Cartek 3X H/C package
ET Performance 215cc H/C package
LG motorsports AFR 205's and G5X4 package
WHICH ONE?????????
Old Dec 7, 2005 | 10:51 PM
just-a-z's Avatar
BTW I am running full bolt ons and suspension, SS3600 Yank, and 12 Bolt Moser 3.73 gears. Also a little spray!
Old Dec 7, 2005 | 11:02 PM
Turbo LS1 SS's Avatar
cartek puts out some gude ****
Old Dec 7, 2005 | 11:04 PM
just-a-z's Avatar
I am going to talk to them tommorrow. I spoke with Lou at LG and his H/C package is also some good ****, only it requires flycutting. Thanks for the input bro
Old Dec 7, 2005 | 11:19 PM
Nittany_marine's Avatar
LG motorsports AFR 205's and G5X4 package...
I have almost the exact same thing but Im running a G5X3. I couldnt be happier. Dont forget to mill those heads, for the extra bump!
Old Dec 7, 2005 | 11:35 PM
just-a-z's Avatar
only bad thing is the flycutting of the pistons, but I hear it isn't too hard to do.
Old Dec 8, 2005 | 12:21 AM
WsSickLs6's Avatar
i say go with the LG setup...
Old Dec 8, 2005 | 12:33 AM
Nate_Taufer's Avatar
ETP's all the way. They will outflow anything (11 degree valve angle) and have less cross sectional area than both other heads listed. That with an EDC cam will easily get you to 440+ in an a4 and 475+ on an m6 with the proper boltons.
Plus if this is on stock cubes that X4 aint gonna fit with milled 205's as it would be in your best intentions to get the static compression up with that setup.
Just check the dyno section for ETP graphs.
Nate
Old Dec 8, 2005 | 03:17 PM
just-a-z's Avatar
So i decided to go with the Cartek 3X H/C package! I will post #'s when I get them
Old Dec 8, 2005 | 03:30 PM
mike c.'s Avatar
i would go with the LG-afr heads w/x4 cam. i have the LG-afr's w/ a x3 cam,but will switch to the x4 in spring. the set up is a killer at the track .
