how long can an ls1 sit without running?
Old Dec 8, 2005 | 09:00 PM
tuffluck's Avatar
Default how long can an ls1 sit without running?
it's been 3 weeks since i ran my car last. it sits outside under a cover. i just haven't had the time. been driving the other one to and fro work. is that too long for the car to sit?
Old Dec 8, 2005 | 09:07 PM
my01camaroz28's Avatar
No it isn't. I used to go to the joint readiness training center for a month and left my car under a car port or in the unit parking lot. It isn't going to hurt it.
Old Dec 8, 2005 | 09:12 PM
redtail2426's Avatar
you southern guys got it easy.Up here in the winter mine sits in a storage facility next to other sick cars for 6 months without starting.I dont even get to see my car.3 weeks is nothing.you do have to prep the car for anything over 2 months though.
Old Dec 9, 2005 | 12:23 AM
42NightZ28's Avatar
I let mine sit for about 9 months when i still had it, the only thing that went bad was the battery but that was alread 3 years old.
Old Dec 9, 2005 | 12:26 AM
LiquidFire350's Avatar
mine sat for a couple months after my hydroplanning accident without starting, hole in the oil pan, in this case it was better to let it sit, had to be sitting for at least 3 months without starting
got it back from the shop, had no problems
Old Dec 9, 2005 | 12:28 AM
Z2K_MrJ's Avatar
Board Certified Idiot
3 weeks is fine..only thing you might have to worry about is a DEAD BATTERY HAHA
Old Dec 9, 2005 | 01:29 AM
aram's Avatar
I left the motor in my camaro sit for about a year after it was wrecked and before I swapped it into my RX7. It started up fine the first time I cranked it.
Old Dec 9, 2005 | 04:06 PM
Derek98z's Avatar
lol
8 Months here only to find a dead battery. If you are going to leave the car for more than one month, unhook the negative side of the battery to help keep it from going dea
Old Dec 9, 2005 | 04:21 PM
Ric's Avatar
Ric
How long can an LS1 sit without running??? Years and years, man.
Starting it after years and years of sitting is another issue altogether.
Old Dec 9, 2005 | 04:25 PM
Ferocity02's Avatar
Mine sat for three months. All I did was add some fuel stabilizer before I left and covered it. It started right up, no hesitation. No dead battery either.
Old Dec 9, 2005 | 05:25 PM
no dead battery after 3 months is impressive.What kinda battery?
Old Dec 9, 2005 | 05:26 PM
Ferocity02's Avatar
Optima red top
Old Dec 9, 2005 | 05:31 PM
99Freeze's Avatar
Mine sat for 2 1/2 months in about 4" of water. I couldn't even get to it. All this happened during that damn hurricane. I thought it was totally flooded out but the big man up stairs said she will run another day. 3 weeks no problem at all.
Old Dec 9, 2005 | 05:34 PM
APeteSS's Avatar
At least a year, mine did.
Old Dec 9, 2005 | 05:43 PM
11 Bravo's Avatar
Mine sat for a year when I was in Iraq. Fired right up with some jumper cables. Of course, the battery wouldn't hold the charge, but that was about it.
Cop Car's Avatar
sometimes if LS1s sit they run choppy, but a few WOT runs and its fine. sitting for 2 or 3 weeks wont be a problem though
Old Dec 9, 2005 | 06:11 PM
slow trap's Avatar
mine sat for 8 months.had a dead battery but drove it around and is holding charge now.stock ac delco.
Old Dec 9, 2005 | 06:15 PM
NX_CaGEdApE00's Avatar
damn mine has been sitting 4 about a year now.. what should i do before running it??
Old Dec 9, 2005 | 07:17 PM
tuffluck's Avatar
good to hear. thanks for all of the feedback!
Old Dec 9, 2005 | 08:00 PM
APeteSS's Avatar
bare minimum is new oil and fuel, check all other fluid levels, tire pressures
