Had gasket removal
Old Dec 9, 2005 | 06:00 PM
Dipstick's Avatar
Am I doing something wrong. The yellow ones do scratch aluminum. Shoulda went with the white one.
Old Dec 9, 2005 | 06:55 PM
RPO_Z06's Avatar
Turn down the speed a little, yellow is what I used with ZERO problems.
Micro scratches won't hurt anything.
Old Dec 9, 2005 | 07:35 PM
Dipstick's Avatar
Will do. It was spinning pretty fast.
Old Dec 9, 2005 | 09:15 PM
Teutonic Speedracer's Avatar
According to NAPA's site the white are best for aluminum. Green for harder metals and yellow for all metals. Think I'll go with white and yellow.
Yup! I used a white one on mine. Grainger sells them also. The green is 80 grit equivalent, I think yellow is 120 or so. Forget what white is.
Old Dec 10, 2005 | 10:04 AM
Dipstick's Avatar
There is a Grainger near me. Will probably pick up a white one Monday.
Old Dec 10, 2005 | 10:55 AM
Billiumss's Avatar
You can use a razor blade if you are careful. Takes about 30 min each side. The block aluminum is harder than the heads. Take your time and clean up with mineral spirts and green scotch bright
I used it on mine and never had a problem, even with N20!
