Had gasket removal
What about using paint remover. The kind that is a jell and melts everything?
http://products3.3m.com/catalog/us/e...er/output_html
What do we need? MORE POWER
dont knock em till you've tried them... they work awsome.. every engine builder i know uses them now... they clean well enough to see the machined surface again, but they wont scuff the surface at all... unlike the scotch pad ones...
the fact that you can clean both block and head surfaces in under 3mins is just a nice plus.. they really do work well.
Now, do I want fine medium or coarse and where can I get them locally. HD or Lowe's have them?
you can get them anywhere you get 3M stuffs... i get mine thru my uncle since he has a shop... i havent used them in a couple years, but only because i havent had to build a motor in a couple years.. lol.
i just went to your website, and saw where you mentioned a "Mendeola S4-S sequential shift transmission" where can i find more info on this trans??
i just tried a quick google search, and all ive found is a ton of sandrail specs.. no real info.
