Rockers tought to torque down?
Old Dec 13, 2005 | 06:37 AM
CBX's Avatar
CBX
Originally Posted by vettenuts
One quick question, if these are ported heads was the bottom of the rocker boss cut off during the porting? If so and you tapped the threads, you may have gotten metal chips in the motor. You may want to check that out before you fire it up.
Good point.
Old Dec 13, 2005 | 05:18 PM
Lithium's Avatar
SSU's Drunk Typing Whore
So you saying I need to pull the head?
Old Dec 13, 2005 | 05:30 PM
CBX's Avatar
CBX
Unless you can think of another way to make sure there are no metal chips in there.
First of all is your rocker boss cut out?
Old Dec 13, 2005 | 05:34 PM
LS1FIRE's Avatar
If its in the intake port and you got your manifold out stuff a shop vac in the intake port.
Old Dec 13, 2005 | 05:39 PM
CBX's Avatar
CBX
That should do it.
Old Dec 13, 2005 | 05:48 PM
Bigrob339's Avatar
Default rocker set up
Hey Bud, Make Sure Rocker Arm Pedalstal Is In Place Properly, Pusch Rods Are In The Rocker Cup, And That The Flat Side Of The Truion Bearing On The Rockers Is Facing Up. You Should Not Have To Turn The Motor Over At All, The Ones That Are Going On Hard And The Ones Where The Valves Are Opening/closing. Once Tight The Lifters Will Then Bleed Off. Good Luck Pal!
Old Dec 13, 2005 | 07:08 PM
Lithium's Avatar
When I took my pedistals off they were upside down. Now in the pic over at LS1Howto - http://www.ls1howto.com/howto/fbody/...valvetrain.jpg - the pedistals are not upside down??
Is there a difference? how should they look?
Old Dec 13, 2005 | 07:13 PM
LS1FIRE's Avatar
Are you talking about the part number casting that was upside down? It shouldnt matter. I rember mine was upside down when i took mine off as well.
Old Dec 13, 2005 | 07:14 PM
Lithium's Avatar
Cool, thanks man.
Old Dec 13, 2005 | 07:32 PM
LS1FIRE's Avatar
Also i remeber chasing the threads on one of the rocker bolts. I had a shop vac in there sucking up all the debrie and a rag but i still felt paranoid after. So i rigged up a straw onto a shop vac to suck into the spark plug hole.
Old Dec 13, 2005 | 07:42 PM
CBX's Avatar
CBX
Cool, thanks man.
Mine were both right side up, but I don't think it matters. I know, at this stage you start to second quess everything.
Old Dec 13, 2005 | 08:09 PM
  #32
Lithium's Avatar
Hahaha hell yeah. I was stressin out at work just thinking about the install - what if this is wrong or thats wrong...maybe I didnt do this or forgot to do that.
AHHHHHH its killing me
Old Dec 13, 2005 | 08:29 PM
  #33
Dipstick's Avatar
Doesn't matter wich way the pedestal is, but it should have been put back the same way it came out.
I just did a cam install and the rocker bolts went in with my fingers. Almost sounds like you cross-threaded them. I hand started mine, then used an air ratchet, then a torque wrench. I torqued them to 22 ft/lb and turned it 180 and re-checked. No change.
Old Dec 13, 2005 | 08:47 PM
  #34
CBX's Avatar
CBX
That sandrail is awesome, must go like a raped ape!
Old Dec 13, 2005 | 08:54 PM
  #35
Lithium's Avatar
Alright now I am onto the headers. And of course the last bolt I thread into the header almost broke off. I need to retap ANOTHER THREAD! This is starting to **** me off to cause I am having to backtrack way to much in this install. I am very very very lucky that this bolt did not brake - thank god for the stage 8's.
So anyway... what size tap do I need for one of threads for the headers.
Old Dec 13, 2005 | 09:40 PM
  #36
chpmnsws6's Avatar
the same size as you need for the rocker arm bolt... now you see why i said you'll need it in the future?
Old Dec 13, 2005 | 09:47 PM
  #37
Lithium's Avatar
No not at all
You think after buying heads for 1,500 bucks the threads would be tapped right???
Thanks again!!!!
Old Dec 13, 2005 | 11:27 PM
  #38
calongo_SS's Avatar
Mental note to self: Check all threads before installing new heads. I just learned something at your expense. Good luck, sounds like you're having a blast.
Old Dec 13, 2005 | 11:30 PM
  #39
Lithium's Avatar
yeah you bet I wish it would never end. Having to backtrack several hours is not that fun at allllll. Luckily it was just one thread for the headers that needed to be tapped.
Old Dec 14, 2005 | 11:53 AM
  #40
Dipstick's Avatar
Sounds like you are doing something wrong. When you install an item, do not tighten any bolts all the way before the other bolts are started. Snug them up by hand if possible, then use a torque wrench on them.
