LPE CNC LS6 heads/GT2-3 pushrod length
Old 01-01-2006, 12:12 PM
Bo White's Avatar
Im gonna guess 425+/- since its a M6 with LTs. Its gonna pick up a little with a tune tweak.
Old 01-01-2006, 12:19 PM
Rob
Rob's Avatar
I seriously doubt that but would be great. FWIW, my tuner says he thinks it'll be 410.
The cam is such a baby, I have my doubts.
Old 01-01-2006, 12:37 PM
redtail2426's Avatar
sweet i cant wait to see the graph.If you dont get to 400 i know it will be real close.good luck
Ed Curtis's Avatar
Cool
I smell a "speed contest" between you and a "certain" red GTO....
Ed
Old 01-01-2006, 12:38 PM
Rob
Rob's Avatar
Ed
That would be no contest. I drove his car while mine was at his house. Insta power but his is a great driver save for that exedy twin disc.
Old 01-01-2006, 03:43 PM
Bo White's Avatar
OK, sorry....was mistaken on which cam this was- was thinking this was the 228 cam
Old 01-01-2006, 04:04 PM
Rob
Rob's Avatar
I'm thinking 39x/39x. I can always hope for more though
Old 01-01-2006, 04:05 PM
Rob
Rob's Avatar
No problem. If I was running a 228, then I'd say you would be right in the ballpark
Old 01-02-2006, 10:33 AM
George V's Avatar
Rob
I am undecided on using the cometics, did you have any problems with them? How much compression did you gain over the stock gaskets?
Old 01-02-2006, 10:45 AM
Rob
Rob's Avatar
No problems at all with them. I figured the bump in compression to be about .2 more.
Old 01-02-2006, 11:01 AM
66deuce's Avatar
Originally Posted by George V
Rob
i used the .045 cometics,no problems.the thing about them though,your deck and head surfaces have to be very clean and smooth.the OEM MLS gaskets are more forgiving.although you will gain a little compression over the OEM gaskets(not exactly sure how much)the main benefit will be a tighter quench.
Old 01-02-2006, 12:37 PM
  #32
George V's Avatar
Thanks for info on the cometics. So what’s the verdict on the cam? I am disappointed to hear that you don’t notice anything below 3K.
Old 01-02-2006, 01:06 PM
  #33
Rob
Rob's Avatar
Its not that I haven't felt anything. Haven't beat on it enough to really tell. It definitely hasn't lost anything down low. Still able to lug the thing around at 1000 in any gear.
The dyno will tell the story
Old 01-02-2006, 01:14 PM
  #34
Felix C's Avatar
Rob,
Are you going to dyno with the GT2-3? Or with the new camshaft?
Regards.
FC
Old 01-02-2006, 01:31 PM
  #35
Rob
Rob's Avatar
Originally Posted by Felix C
Rob,
Regards.
FC
No new cam, still the GT2-3.
Old 01-02-2006, 01:50 PM
  #36
George V's Avatar
The suspense is killing me….
Old 01-07-2006, 07:01 AM
  #37
Rob
Rob's Avatar
Results are posted at
https://ls1tech.com/forums/showthrea...10#post4043910
Old 01-07-2006, 07:16 PM
  #38
George V's Avatar
Thanks Rob, looks good
Quick Reply: LPE CNC LS6 heads/GT2-3 pushrod length
